Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SuperRam porting gain improvements?
Old Sep 18, 2005 | 03:32 PM
brutalform's Avatar
Can any one tell me what kind of gains they realized on a complete porting of the SuperRam base, and runners? Preferably on a 400+ cube engine?
Thanks. Tom
Old Sep 23, 2005 | 10:24 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
27 hp and 36 fl lbs at the wheels.
Old Sep 24, 2005 | 12:44 PM
brutalform's Avatar
[B]
Which wheels? The front ones? Also, are you sure its not 28, and 37?
Old Sep 24, 2005 | 12:52 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
You will only pick up 40% of the gain through the front wheels.
Old Sep 26, 2005 | 04:59 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I doubt that anyone has a good comparison for you. All I can tell you is that my ported SR pulled 340 RWHp in my 395 cu.in. stroker. see sig for more details.
I do not have a good before and after answer for you. I made multiple changes.
Old Sep 27, 2005 | 12:31 PM
brutalform's Avatar
[B]
Thanks doc. I have an unported one on a 436. The base was modified to mate to the large ports of the Track 1 heads, but as far as the runners go, they are as cast. Just wondering if it would be worth the effort. Just trying to get every bit of power I can from my combo.
Old Sep 27, 2005 | 03:58 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I recall John Lingenfelter telling me that a fully ported SuperRam was worth 20 HP. I never asked about torque or at what rpm.
Call LPE directly for some direct information.
www.geocities.com/dzperf
Old Sep 27, 2005 | 10:32 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
20hp over unported? I though the SR only added 20hp or so over a Modified LTR. SO like 40+ over a modified LTR? ( I know it depends on combo) but that really sounds like alot, and no I'm not saying that it can't be true.
Old Sep 28, 2005 | 07:23 AM
brutalform's Avatar
[B]
I was hoping to get some real numbers from a regular guy. Alot of times the large companies(not all of them) will tell you what you want to hear, just to sell their product. I would assume that the gains,(if any) would be more noticable on a large engine, over a 350, or 383.
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Reid Fleming
Oct 10, 2015 09:56 PM
wanext
Oct 6, 2015 12:18 AM
