Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
93 LT1 TB not working with 93 TV cable with 700R4
Old Oct 9, 2005 | 11:58 AM
Firebat's Avatar
Have a 95 LT1 connected to a 700R4. Using the 93 Throttle body and 93 t.b. bracket. Using TPI cable for the accelerator. Using 93 TV cable.
Problem is that i'm not sure how to hook up the 93 tv cable to the throttle body. There are two places to possible hook it up and i assumed it was the upper post thingy, not the lower. Because the lower one exists on the 94-97 TB and is used for cruise control i think? Anyway, hooked up the tv cable to the upper post and now can't get the TB to fully open. So, do i have it hooked up wrong, or is there an adjustment needed to be made, or am i using the wrong cable?
i also posted this in the engine swap forum but i'm guessing some of you who put on the LT1 intake as an alternative might have also put on the lt1 throttle body and lt1 tv cable.
Old Oct 11, 2005 | 01:54 PM
Firebat's Avatar
Figured it out.
https://www.thirdgen.org/techbb2/sho...91#post2572091
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
fonzie85
Aug 13, 2015 11:50 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
