Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Lt1 intake
Old Nov 29, 2005 | 05:09 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Lt1 intake
What exactly has to be done to a LT1 fuel rail for it to be compatible with some stainless braided AN lines I have? Do I need special fittings or do the fuel rails need something welded?
My stock tpi rail needed a special fitting for the return and someone had previously welded an AN fitting directly to the rail for the fuel supply.
Old Nov 30, 2005 | 08:03 PM
Z69's Avatar
Z69
Several methods-
You can buy push on adapters for the stock Lt1 steel rail lines.
You can get the stock steel lines flared to 37 degrees and use tube nuts and sleeves.
You can use -5 and -6 Aeroquip versa flare adapters.
You can have male AN adpaters brazed to the stock steel lines.
Old Dec 19, 2005 | 10:15 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
click here for some ideals
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
