Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Is there a 4bbl TB with 700r4 brkt?
Old Jan 1, 2006 | 12:17 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Starting my Vic Jr EFI project. I need a 4bbl TB with the correct 700r4 cable connection and cable bracket. Does anyone know of part #'s or suppliers? Thanks.
Old Jan 2, 2006 | 08:55 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Take a look on this link to holley:
http://www.holley.com/data/Catalogs/...0Injection.pdf
Bracket 20-113 for there commander 950 system throttle body. I'm using it on a different TB with minor mods, but it's not auto. Look at the linkage on this TB to get an idea of what you will need to make it work. The TV cable hooks up to the rear of the linkage.
EDIT- Also be aware that not all TB's will fit. The linkage on this one hits the fuel rails on a pro-ram, and required a 1" spacer to get it to clear.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
6998poncho
Sep 25, 2015 02:56 PM
