Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
How to change/measure/set Fuel Pressure in HSR?
Old Jan 12, 2006 | 10:50 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I don't feel like registering at stealthram.com for one question so please don't suggest it. I got the holley adjustable fuel pressure regulator and have a FP gauge on my fuel rails. I'm wondering if the car has to be running. And I remember hearing just pull the vacuum hose, correct? Does anyone remember which way turning the set screw raises/lowers the pressure? Thanks!
Old Jan 13, 2006 | 12:15 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
TTT, im on this step. I think im gonna hook up a guage to the fuel rail somehow and set it at 40.
Old Jan 13, 2006 | 01:33 AM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I usually set my fuel pressure by manually jumpering my fuel pump with the engine off. I have a gauge permanently in the rail.
You are pretty much forced to remove the vacuum line from the regulator in order to adjust it. I'm pretty sure clockwise increases fuel pressure, but it'll be immediately obvious when you make a change.
-Dave
Old Jan 13, 2006 | 01:55 AM
Car: 86 T/A
Engine: HSR 355
Great. Also, do I just remove the hose entirely and cap off the port on the back of the plenum?
For those that care:
I bought a fuel pressure gauge, and quickly realize that it wouldn't fit due to the location of the fitting on the gauge. Well I used an extra 90* elbow that was original connected the oil pressure sender to the intake manifold.
Old Jan 13, 2006 | 04:02 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally posted by firebirdjosh
Offtopic...
Nice 4thgen MC. Is that 93-97 style or 98+?
Old Jan 13, 2006 | 08:09 AM
Car: 86 T/A
Engine: HSR 355
98+. Looks better, has low fluid sensor, and is easier to refill. I think I paid $20 for it as well.
Old Jan 22, 2006 | 03:36 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You can simply turn the key to the ON position (do not start engine). You should hear the fuel pump turn on and prime the fuel rail. The peak fuel pressure that you reach doing this procedure is the same fuel pressure at WOT and same as engine running with vacuum lines pulled & plugged.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
