Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Project_HSR on 86 camaro
Old Jan 19, 2006 | 01:45 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Hello all, I have used this website for lots of useful tips and information, but only recently have I started posting. Here is my deal I purchased a 1986 Camaro with the 305 carb motor. I have put in its place a 355 Holley stealth ram engine. I am using the wiring harness and computer from a 1989 GTA, I have all the equipment to burn and monitor my own chips I have a 2000 stall converter with a transgo shift kit in the tranny and the rear end is yet to have anything done to it. I have not yet had the joy of firing it up, I work weird hours, I am an Operator at an Industrial chemical plant in Texas on the gulf coast. Modifications that I plan on are very simple, 3 toggle switches 1 for fan 1 for the ignition, and 1 for the fuel pump, which is a holley inline fuel pump since the carb'ed motors had a mechanical fuel pump. Another modification is the addition of a B&M shifter. I am sure the mod list will get longer but that is all for now. I am going to post a few pics so you can take a gander or use them for information. Thanks!
Old Jan 19, 2006 | 01:48 AM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Damn, dude. You need either a bigger image, or a better resize.
Old Jan 19, 2006 | 01:49 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
sorry new to posting will try to get it right
Old Jan 19, 2006 | 09:41 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yeah I'd love to help once its easier to read. Crop that massive white border out of the picture.
Old Jan 19, 2006 | 01:21 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
fixed..
-- Joe
Old Jan 19, 2006 | 06:28 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I don't think you will need the 3 toggles, the 89 GTA computer will control them for you.
Old Jan 19, 2006 | 07:14 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
3 toggles
I like the fact that I will have switches, don't know why just always wanted a car with toggle switches, some of you out there might understand. And since I can make them useful why not? Plus I made an aluminum panel to go in place of the stock shifter cover (see pic).
Old Jan 19, 2006 | 07:43 PM
Car: 86 T/A
Engine: HSR 355
Very cool. I just converted my 86 over to a 355 HSR and I'm gonna fire it up this week. My main problem was converting the distributor over to a remote mount coil (86 has in cap) so it took a while to get parts, wire, mount the coil, and set timing. If you have any problems check www.stealthram.com as well.
Old Jan 19, 2006 | 08:34 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
better pic of engine
Here is a better picture of my HSR project engine, almost there.
Old Jan 26, 2006 | 10:23 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Here is another pic for those who are interested.
Old Apr 3, 2009 | 12:55 PM
86 406's Avatar
Re: Project_HSR on 86 camaro
Where did you mount the ecm and drill the fire wall when going from carb to hsr?
Old Apr 4, 2009 | 01:56 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
The great thing was I didn't have to modify anything, it all went right where the carb computer and harness went.
Direct bolt in!
Old Apr 6, 2009 | 02:45 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
looks good i'll be doin this too when i do my motor swap
Old Apr 6, 2009 | 02:56 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
i plan on doing an aftemarket efi set up on a project im starting to plan...hows the tunning wiht the holley setup...iv hurd the least bad news about it... i just think in pics it looks too much lik the stock tpi set up what do u think?
Old Apr 7, 2009 | 11:01 AM
tom86iroc's Avatar
Car: 1986 iroc
i'm gonna be using FAST setup for efi i just bought the intake nad plenum
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
