Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
couple questions
Old Feb 8, 2006 | 10:04 AM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
couple questions
i read the sticky and that kicked a few off for me. im looking to go in directions that baffle the normal people
when mounting injectors how important is angle? can they be mounted on thier side? i have a few thoughts rolling thru my head.
1. using a crossfire intake, obviously open up any restrictions, mount rails somehow and injectors (i havent seen a crossfire in about 3 years) use 2 ls1 style throttlebodies and connect to a twin turbo setup.
2. pretty much same as above but on a duel tunnel ram type intake
3. on a victor like most of you guys have. i priced it out with costs for a megasquirt and its actually quite close if you buy the rpm pro flo then individual parts
4. im kinda partial to the crossfire setup only because no one else uses it, but thats for a reason. so as a decent fabricator with a mig, cost wise where is a good place to start?
engine im going with is a 355 off of a 350 4bolt. heads and cam are up in the air at this point. i only have enough cash for free catologs
i would like to start screwing with this this year and really go full bore next after we get our house.
what computer systems are you using, intakes, throttlebodies, forced induction? i know i want at least 1 turbo. the vehical im looking to do this in will be an s-10 pickup. just because i want an awd monster. i plan on using rear mount turbo system. i have a good grasp on that now im moving to what im boosting.
thanks
ps i like pictures
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
