All parts needed for HSR install
Hey guys, its been almost 3 years since i've been on here last, but anyway my question is im switching from tpi on my 88 iroc to HSR I got the intake the fuel rails, and the regulator and those two little gaskets. But what else do I need exactly to complete the conversion?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Stealth Ram manifold #7540 (summit racing) $299.95
Fuel rail kit w/regulator #534-186 (summit racing) $215.39
Fuel line kit (supersportperformance) $119.99
Water neck MrGasket #2661 (PIC) $13.99
Flex hose upper radiator Advance Auto 12228 (PIC) $10.65
Intake gasket $12.99
Antifreeze (1 gallon) $7.99
Permatex Blue Silicone $3.99
5/8" hose barb for heater hose 1/2" thread $2.99
Total $687.93
Other incidentals (things that not all will need)
Small cap distributor (85-86 has large cap) $50.00 (used)
Square beveled washers w/ 3/8-16 1 1/4" long bolts $10.65
Total $60.65
Total $687.93
Total $60.65
my question on that one is what is this fuel line kit? i already have the fuel rail kit, is it necessary for this fuel line kit, if so where can i purchase that cause the stealthram site i clicked on the fuel line kit and nothing came up.
The HSR uses AN fittings and has the lines attach at the rear of the intake.
So you need adapters to go to the stock steel lines at the frame and longer hose to go to the back of the intake.
The longer hose comes with the AN fittings to fit the rail.
hectre13
Dec 11, 2023 08:14 AM
