I would like to order a lokar cable and bracket for my hsr but looking at summit there is a 24" and a 36" for tpi. I have a 89 iroc with a with a 5.7 and a holley stealth ram and it is a manual not a auto.
Quote:
Measure the one you got, at least to the firewall. A 12 inch difference in the two, should make it pretty easy.Originally Posted by ml258-89iroc
I would like to order a lokar cable and bracket for my hsr but looking at summit there is a 24" and a 36" for tpi. I have a 89 iroc with a with a 5.7 and a holley stealth ram and it is a manual not a auto. Junior Member
which one did you use?? My stock one is binding with the new hsr installed.
go with the 36" they are cut to fit and that way you know you have enough. I am pretty sure that is the cable I got but mine is for a carb app.
I'll measure mine when I go out to work on it later
I jst noticed my TPS is reading 80% and I have to stand on the pedal to make go to 98%. Disconnected the trans cable and it opens easier and smoother. So I guess its actually my trans cable binding or something. How does the kickdown cable work? Any way to run without it?
Quote:
TV cable might simply be adjusted too tight. Might be bottoming out the valve..Originally Posted by MSchumacherfan
I jst noticed my TPS is reading 80% and I have to stand on the pedal to make go to 98%. Disconnected the trans cable and it opens easier and smoother. So I guess its actually my trans cable binding or something. How does the kickdown cable work? Any way to run without it? -- Joe
Just measured mine and it's a little less than 24".
