Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
stealth ram and heads - what ones?
Old Mar 21, 2006 | 03:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm thinking (again) about getting a stealth ram.
Initially the plan was a vortec stealth ram with E-tec 170s.
For the same money, I can go with a standard stealth ram and any of a number of different heads, including Trick Flows, or the new Patriot 195s which seem pretty interesting.
I have a hydraulic cam, and I don't have the budget to upgrade to a roller, but a new hydraulic cam won't break the bank. Currently I've got a 214/224 .442/.465 112lsa grind.
I've got a MAF system but I'd probably convert to SD with the HSR/heads upgrade.
The short block is a .030 350 with flat top forged slugs.
I would like a nice broad, flat torque curve similar to what you'd see from an LS1. I love my TPI torque, but I realize that the HSR is an entirely different type of system. I just don't want a high-rpm strip car that's got no low end nut for the street.
So... what do you guys suggest?
Old Mar 21, 2006 | 08:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im running AFR 190's with my HSR and I think its pretty good. my cam is a little bit bigger then your but I also have a 383 as well. Theres a lot that gonna change when you switch over. I think your best bet is to head over to stealthram.com and see what those guys are running. I have only used one pair of heads so I cant compare.
Old Mar 21, 2006 | 08:34 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Bottelfed if you dont mind me asking what cam are you running hows the car drive and have you had it to the track?
Old Mar 21, 2006 | 08:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
my cam specs are as follows. 224/230 .502/.510 (w/1.5rr), 112 LS. I have not had it to the track. I put down just over 300rwhp on a MD Mustang Dyno. Most guys say those dynos read lower numbers becuse the dyno puts a load on the car so the numbers you get are actual numbers. Anyway, I planon getting some times when the tracks around here open
Old Mar 21, 2006 | 08:48 PM
Car: 89 Formula
good news Might I ask if thats a roller or flat tappet and who manufacturers it? Im putting togeather a similar set up (eventually) but with E-tec 200s
Old Mar 21, 2006 | 08:49 PM
BOTTLEDZ28's Avatar
Transmission: A4
its a comp cams hydraulic roller cam.
Old Mar 21, 2006 | 08:52 PM
Car: 89 Formula
thank you sir
Old Mar 21, 2006 | 09:03 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I am running AFR heads too on my 383 HSR.
Old Mar 23, 2006 | 08:16 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
im running dart iron eagle 215s on my 383.
Old Mar 25, 2006 | 05:07 PM
blackroc68's Avatar
WHY not e-tec 200!! I used them on my 383 with a scoggindickey tpi manifold,zz9cam.It was a beast.
Old Mar 25, 2006 | 05:17 PM
Car: 89 Formula
Old Mar 26, 2006 | 09:39 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I am running 355ci, TF G1 heads with HSR, hot cam, 700r4, 3.73 gears with a 2600 stall, thing roasts the tires no problem off the line as if I am brake torq'n it. I have had an LT1 intake and stock tpi on this motor also, the HSR is the best all around, better low end than the LT1 and better top end than the stock tpi.
Old Mar 26, 2006 | 07:27 PM
z282slo's Avatar
Car: 91 z28
I have my stealthram on top of pro topline 200's with a cc306 cam and with a good tune it has plenty of street manners, but by the top of third it's kinda scary for public roads
Old Mar 29, 2006 | 03:11 PM
Jim85IROC's Avatar
Seems like way too much head for a 350 with a mild-ish cam.
Old Mar 30, 2006 | 10:30 AM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I'm putting that combo on my 406. You're right about the cost (i sold my regular HSR and bought a VHSR), but after reading up on the E-tecs, they sound like a quality piece with solid results. I don't doubt AFRs would probably be better, but I went down to Summit on a weeknight and walked out with heads. No muss, no fuss.
I'll try to post results once I get it back together (hopefully in the next couple weeks)
-Dave
9192camaro
16
Feb 3, 2019 12:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Mutillator
Sep 17, 2015 04:38 PM
z28guy134
Sep 1, 2015 11:50 PM
L98GTA87
Aug 11, 2015 06:55 PM
