Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Lt1 intake bolt problems
Old Apr 7, 2006 | 01:05 PM
CamaroCrazy23's Avatar
Car: 1991 Z-28
Engine: AFR ELIM 195s,280xfi,58mmLt1 Intake
Transmission: 2200stl,700r4 shift kit,vette servo
Axle/Gears: 28 spline, 3.42 gears, SLP Posi
So all you lt1 intake owners out there how did you get your bolts on the driver side under the pcv and vacuume lines in? im haveing troubel and ive tried a few differnt bolt styles.
Its not that they wont thread its that they cant get to the right angle to bolt in.
would i have more clearance if i went to intake manifold studs?
Old Apr 7, 2006 | 09:43 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
This what you need?
Look closer at these two center holes, grind lots into the casting to get the bolts to start because of the angle of pre '87 heads. Late model heads won't have this problem.
midge54
Dec 27, 2019 04:14 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
