Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Miniram is ready to go on :o)
Old Apr 10, 2006 | 06:07 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
What do you think?
Attached Thumbnails Miniram is ready to go on :o)-miniram.jpg
Old Apr 10, 2006 | 06:08 AM
Car: 89 formula 350
another
Attached Thumbnails Miniram is ready to go on :o)-minram2.jpg
Old Apr 10, 2006 | 06:09 AM
Car: 89 formula 350
last one
Attached Thumbnails Miniram is ready to go on :o)-miniram3.jpg
Old Apr 10, 2006 | 08:38 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Did you use red paint or red powdercoat? Picked up the injectors and throttle body yet? How about the coolant neck? I got a coolant neck from TPIS and it was like, $19. It fit perfctly.
I like the button cap fasteners on the fuel rails-- nice touch.
You seen my setup yet? It's similar but based on the original miniram. It works wonderfully. You will like yours when it's installed, I am sure.
http://www.ws6transam.org/miniram385e.jpg
Old Apr 10, 2006 | 10:10 AM
Car: 89 formula 350
thats um...yellow lol. I used red paint on mine.
Old Apr 10, 2006 | 12:28 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
You most definantly need to install 3.70 gears or more, or your will loose that bottom end torque. Anyway, TPIS suggest 3.73 or higher.
Old Apr 10, 2006 | 12:57 PM
Car: 89 formula 350
im looking at some 3.73 gears from Randys ring and pinion, or maybe a 4thgen rear for now
Old Apr 10, 2006 | 07:10 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
is that the monoblade opening i see on the front!!!! is that what your using for the tb (the 1300 monoblade)?
looks good
Old Apr 10, 2006 | 09:37 PM
Car: 89 formula 350
im using a BBK throttle body...Ive heard from some people talking about a big oval monoblade throttle body that SLP used to make but I havent seen anything on it before...
Old Apr 10, 2006 | 10:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run a 383 Mini with stock 3:27 gears and an S-10 converter. I have more torque then I know what t do with.
Old Apr 10, 2006 | 11:29 PM
@ZZKKER's Avatar
tpis makes the monoblade. just do a search at CamaroZ28.Com - FULL THROTTLE INTERNET
lt1 guys use it more than us.
thanks
anthony
Old Apr 11, 2006 | 09:11 AM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Talked to Chris at TPIS this morning and they don't produce thier mono blade anymore. Arizona Speed & Marine makes a monblade, I tried to call to verify but they are still closed on mountain time 2 hours difference.
Old Apr 11, 2006 | 09:18 PM
Car: 89 formula 350
eh im not interested in it anyway lol
Old Apr 11, 2006 | 09:21 PM
@ZZKKER's Avatar
no ****, whats the world coming to when you cant buy the $695 monoblade from tpis. as&m still makes them, but you wont like the price. what you will like is that fact that you have just bought the most bad *** tb that money can buy!
Old Apr 14, 2006 | 12:44 PM
Car: 89 formula 350
tpi comes off tonight. Miniram goes on tomorrow
Old Apr 14, 2006 | 02:36 PM
Twisted92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L 350 TPI
Looks sweet, cant wait to see the pics of it on the car. I'm saving for one myself atm Mid may i hope
Old Apr 15, 2006 | 07:28 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
im going to be putting mine on in the next week or so is there anything as far as tuning that needs to be done before the intake goes on?
Old Apr 15, 2006 | 03:05 PM
Car: 89 formula 350
well the intake is bolted on now. Im going to let it sit overnight. Monday I am going to finish assembly. TPiS really dropped the ball on the fuel rail instructions though. They just send you a coil of braided line and some fittings and you're supposed to figure out where they go. Normally that wouldnt be hard, but I think im missing some fittings. We'll see. Pics soon!
Old Apr 15, 2006 | 11:50 PM
Car: 1992 Z28
goodluck, hope you get it all working cant wait to see the pics
Old Apr 16, 2006 | 07:00 AM
Car: 89 formula 350
quick pic of it on. Ran out of time, but all I really have left is to fab the fuel lines, distributor, tb, and relocate the MAT.
Attached Thumbnails Miniram is ready to go on :o)-.jpg
Old Apr 16, 2006 | 07:22 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
i like it can't wait to get mine started i see you put a t56 in your car did you ever try driving the car at all before you got the vss hooked up to the dakota digital box? because i just did my swap and the car ran fine before and then i drove the car after and i didn't have the vss hooked up at all and it runs really crappy now!
Old Apr 16, 2006 | 10:23 AM
Car: 89 formula 350
yeah. You need to get a chip burned for a manual car now. My car was the same way. I couldnt get the dakota box to work, so I havent had a speedo for a couple years lol I had a buddy of mine do a speed density swap on my car, and with some creative programming in the chip, he should be able to get my speedo working through the speedo buffer in the 730 ecm.
At least thats how I think it works lol
Old Apr 16, 2006 | 11:13 AM
@ZZKKER's Avatar
if you look at the back of your pontiac cluster, there are 3 or 4 screws that connect directly with the spedo, one has an s (signal) and the others are marked for power and ground, but it has been a while since i did mine. then you just run another signal wire out of the box to the vss input on the pcm.
Old Apr 18, 2006 | 06:48 AM
Car: 89 formula 350
Went to my machine shop last night. They cut my braided line and installed my aeroquip fittings. I have the fuel lines and injectors in. I reconnected my vacuum hoses, and coolant hoses. Installed the CTS, and thermostat. I started to cut the coolant nipple off the TB but I really need a bench grinder to finish that.
I ran out of time last night...had a family emergency. Hopefully I'll be able to bolt the distributor on, relocate the mat and install the TB/air intake duct, finish my wire looms, and take it for a test drive My new chip for the intake/30lb injectors should be in today, so I'll be ready to go!
Old Apr 19, 2006 | 09:16 AM
Car: 89 formula 350
Gave everything a double check, all looks good. MAT is relocated and air intake is on, radiator is full of coolant. Im taking baby steps huh? LOL Anyway, I go to drop the distributor in last night and notice the gear is worn oddly. Upon further inspection, the damn distributor shaft was bent! I have another distributor with a bad pickup. Both distributors are at the shop now getting parts all swapped out so I will have one good distributor to put in. Hopefully I'll get to start it tonight.
Sucks when you dont have a lot of time to work on the car
Old Apr 21, 2006 | 08:37 AM
Car: 89 formula 350
Got it all buttoned up last night. Distributor dropped in, wires in the looms etc. Turned the key, and fuel everywhere Apparently when people say "you dont need those injector clips" it means, "you DO need those injector clips" lol I went to take my clips off my stock fuel rail, and long story short, I need new clips. Local dealer has em for $8 a piece, or I can get them from Summit for $4.88 for 8. I wont have them till monday though, and thats if I pay an overnight fee I might just go to the dealer. I need to finish this intake and get some miles on the car. I have some upcoming road trips and car shows!
Not enough hours in the day....
Old Apr 24, 2006 | 02:09 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
hey justin just about got mine finshed up i had no problems with the fuel rails leaking i ran it with out the clips but my problem is the water neck it puts my upper rad. hose right on top of my belt did you have this problem?
Old Apr 24, 2006 | 04:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
You have the wrong waterneck. You have the corvette one.
Old Apr 25, 2006 | 12:15 PM
Car: 89 formula 350
The waterneck I got looks like a damn stock waterneck that they cut and re-welded. Or a corvette one should work. Or one with a swivel neck. I got everything together and hope to fire it up tonight!
Old Apr 26, 2006 | 06:52 PM
Car: 89 formula 350
Well, all I gotta say is daayummm!! Car pulls like a train right to 6200 now with ease. You do lose some torque down low, but its more than made up for up top! I dont think its the BEST way I could have spent $1300 as far as performance goes lol, but it was definitely a step in the right direction!
Old Apr 26, 2006 | 07:09 PM
@ZZKKER's Avatar
might not seem like a good way to spend 1300 right now, but put some afr's on there with a monster cam and you will be happy. hell, just ported vette l98 heads with a .530 lift cam would kick your *** into the seat.
glad to hear you got it running.
Old Apr 26, 2006 | 08:18 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
i cut down the water neck looks like it will work now i haven't driven the car yet but gave her a couple revs the throttle response is about 5x better then the stock style stuff so its off to get new 3 inch y pipe back put on then its off to get it dyno tuned this sunday can't wait to see what it does
Old Apr 26, 2006 | 08:48 PM
Car: 89 formula 350
keep us posted!
Old May 1, 2006 | 12:55 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
ok car made 291rwhp and 301rwtq i was hoping to see over 300 all the way around but it didn't happen still killed a 300 hp wrx on the way home i guess i will start looking at a charger kit
Old May 2, 2006 | 06:55 AM
Car: 89 formula 350
is your car properly tuned? I've heard that you need extensive tuning with the miniram...or something. I dont know. I DO want to see PCMForless down in NC and get a dyno tune
Old May 2, 2006 | 08:51 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
thats who did my tune it was on the dyno when they tuned it it only made 260rwhp the way it rolled in and 281rwtq so for only spending $275 i got my car dynoed and picked up over 30hp and 20tq so not to bad they thought it was good numbers i kinda have a small cam and said i should have had the heads and intake ported and the hp drops off at 5800 it still pulls past that but it just goes down hill right after 5500
Old May 2, 2006 | 01:28 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Dont mean to get off subject. I was considering doing the miniram but then i read about some kind of uneven air flow things and it got me scared. Something about them running lean. Was this just a myth or is there any solid proof to this?
Old May 2, 2006 | 02:35 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
works fine for me as soon as it was bolted on took it for the first rip it was a hole new car very happy
Old May 2, 2006 | 05:13 PM
shaggy56's Avatar
Car: 71 Nova
Here is a quote from the thread and i found this in a couple places.
The problem with the LT1/MiniRam is that the rear cylinders run rich when idling. According to TPIS, at full throttle the front cylinders tend to be rich as the speed of the incoming air tends to run towards the back of the plenum.
The only real way to compensate is with a sequential fuel inj. system. I'm using a wideband to keep my idle fuel close to 14.0 and run slightly rich at WOT (12.6-12.8).
Old May 2, 2006 | 07:20 PM
@ZZKKER's Avatar
that is true to some extent, but remember, your tpi setup was/is the exact same way on the air flow being uneven.
it does not really cause to many problems, especially for a mild street motor. you might need to tune it a little different if it were a huge cam'd motor, but still nothing to defer you from buying a mini ram on just that principle.
Old May 2, 2006 | 07:29 PM
Car: 89 formula 350
yup. the lean problem shouldnt be worried about on your motor
Old May 2, 2006 | 07:31 PM
  #42
shaggy56's Avatar
Car: 71 Nova
They just seemed like a headache to tune is all.
gixxer92
Apr 12, 2022 12:09 AM
meeklay812
Oct 1, 2015 03:46 PM
skip91
Sep 22, 2015 10:25 AM
BWilcox
Sep 20, 2015 12:19 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
