LT-! intake conversion vaccum and coolant passages.
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
can you help me with how i should plug pcv and the bridge to the front on intake... and the MAP sensor hole do i need it on my 1989 equiped with MAF?
some pictures would be apreciate
thanx
thanx
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
use an lt1 pcv valve, then connect the valve to a vaccume port right next to it. it is how the factory did it. then you can just run a nice breather on the valve covers. thats what i did.
fyi: only the factory replacment pcv grommet and valve should be used do to the aftermarket stuff not fitting well.
as for the map, i left mine in becuase i am going to switch to a speed density setup or possibly a maegasquirt if i like how tibo's new one works. if you are going to stay maf, then just find a tight rubber plug and stick in or have it welded up then paint it.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is a port underneath the throttle body for the PCV line to plug into. That's where I ran it on my brothers car, and its where the factory routes it to. Just need a little 90* rubber elbow on the front port. I used some of the factory LT1 provisions to get it hooked up.
EDIT: this might not be as feasible for conversions with the coolant nipples in the front. Oh, and as was said, then just use breathers in the valve cover for the fresh air part.
the pcv can just be ran to the port next to it. less clutter in an already cluttered engine bay.
...ok
I just bought a kit of 2 breether and 2 gromet...in the kit one gromet is a plug and the other one is a hole...witch one goes on what side...soo i need a bridge between the plug under the tb to the biggest on the driver side. what about the 2 nipple on the tb unpluged??? im all messed up!!!you guys have all a different routine!!!!plz draw me a fast photoshop would help alot!
Originally Posted by erummel
Hey not that anyone cares, but the pic of the intake that @ZZKKER attached to his earlier post is mine.
i just have plugs on my tb nipples because i didnt need to use them because the pcv system is all self contained in the intake now, i did not want to have oil find its way back into the tb to coke it up like on the stock setup.
the cv's find their way into the intake through the bottom cover.
you can do what you want, but if you use the tb hoses to to the valve cover, use a grommet that has a guard to keep mass amounts of oil from finding its way into the hose.
ok
i want the evrything not essential removed..because all hoses from lt1 intake are missing. i dont have emission control in canada so i dont care..im gonnna do the simpliest thing.
that would be 2 breathers if your valve covers are aftermarket like mine (mine only have 2 holes, one on each side), or if you have factory, 1 breather per a side then plugs were they are needed.
i used zoops ball milled breathers on mine because my covers are ball milled and it also matches the intake.
Hotrodboba400
Dec 10, 2019 07:07 PM
