tpi to HSR swap, need help with connectors
Subscribe
May 4, 2006 | 12:44 PM
Hey there, i am just putting the finishing touches on putting on the HSR, along with a bunch of other new goodies. I was wondering how everyone else setup the sensors when they switched from tpi to the HSR. Also, does anyone know what a 2 pronged connector, black and yellow wired, does? it's an 87 gta, and i obviously didn't take good notes when i took it apart.
Reply 0
May 15, 2006 | 02:23 AM
your connectors will go in the stock locations basically. you can change around the vacuum fittings/connectors in the plenum /throttle body to suite your fancy. the yellow and blk wire should be for the coolant temp sensor that will now go on the intake base.
Reply 0
Subscribe
