Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR leaking
Old May 7, 2006 | 06:56 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
HSR leaking
anyone have an idea why i always get anitfreez puddling up here? not sure if you can see it well in the pictures, but its on the very front passenger side of the intake. thanks in advance
Old May 8, 2006 | 01:25 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Did you coat those bolts that run into the water jacket with anything?
Old May 9, 2006 | 02:34 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That's what I would be thinging also. If you didn't put anything to prevent the leak around the bolts it's going to just keep filling up. Also, you said it was on the passanger side. Do you still have the coolant tube hooked up to your TB? It's far fetched but it could be leaking from there also.
Old May 10, 2006 | 11:28 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I had that happen to me....it was the water neck gasket that was leaking. Make sure it is tight...if it is....then you need to replace the gasket. I recommend the GM gasket....I tried a off brand name and it leaked....went with the GM...no more problems.
Old May 10, 2006 | 01:25 PM
Car: 89 Formula
Engine: 5.7 TPI
i dont think i coated them with anything, i dont remember now.
the coolant tube is not connected to the throttle body anymore, a friend that helped me did a bypass on it, not real sure how he did it though, ill check that out.
thanks everyone
Old May 20, 2006 | 04:02 PM
86and96's Avatar
Car: 86 Camaro, 96Formula
Engine: 383HSR, 350LT1
Transmission: TH350, T56
On the HSR, the bolt for the thermostat waterneck on the passenger's side goes directly into the water passage, you will need to put pipe sealant on at least that bolt.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
