help with cam choice on new combo
Subscribe
Jun 14, 2006 | 01:04 PM
Hey guys like the title says i need help in deciding cam choice for my combo. My car is a 88 350ci with Holley Stealthram, and I'm leaning towards the Dart Pro-1's, but for the cam I am not sure, just wanted to mention it here so everything match's up, and I am looking for 300-350 rwhp. I was alos looking at the new Lunati "Voodoo" cam which looks promising 227 int. 233 exh. duration with .489 int .504 exh lift. Any advice or any comments is greatly appreciated. Thanks for the help guys
Reply 0
Jun 14, 2006 | 10:00 PM
Quote: ...and I am looking for 300-350 rwhp. I was alos looking at the new Lunati "Voodoo" cam which looks promising 227 int. 233 exh. duration with .489 int .504 exh lift.
Lift seems quite low. What is the LSA and advance on that broomstick?
Reply 0
Jun 16, 2006 | 11:33 AM
Yeah I got the specs off of my summit mag and not sure where the hell i put it now but i think the power band range wasa 1800-6200 rpm, which is why i concidered it b/c thats exactly where i want to make my power. But other than that what are your opinions on the stealthram with those heads and that cam, but like you said maybe a little HIGHER lift
Reply 0
Jun 16, 2006 | 05:50 PM
what are the flow numbers for those heads, that would help in trying to figure out a cam. Also your gear ratio, if your a auto what size stall, would be very helpfull.
Justin
Reply 0
Jun 16, 2006 | 07:57 PM
The Dart Pro 1 heads can handle .600 lift if you order them correctly. Take advantage of the lift as it will be "free" horsepower compared to a lesser cam. With the combination you are looking at I would expect 400 HP at the motor if not more. I would look at the Comp Cams XFI series. You can order a 224/230 cam as the lobes are in the catalog.
Reply 0
Jun 16, 2006 | 08:37 PM
thanks for the replies i'll be looking into the xfi series and as for the rest of my car its auto 700r4 stock stall and stock 2.78 gear ratio i believe i know its sad. Just trying to build a my dream car here after i get back from the army basic training.
Reply 0
Jun 16, 2006 | 08:38 PM
you wont be able to go very big on a cam till you get a stall in there, that or driving the car around will SUCK.
Reply 0
Subscribe
