Just ran Best ET ever, tonite
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I did pretty good tonite with a best ET ever of 12.197 sec @ 113.65mph.
60' time on this run was 1.77 sec.
Car details are in my sig,,, I will change the dragstrip data after this post, so what is listed below is my previous best time, BTW at the same dragstrip.
The only difference in the car are the govenor weights in the 700R4.
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Doc - Nice ET.
To give you a little history, I had a SuperRam on my 383. The car ran 12.0's all day. Very consistent and predictable. Pretty much the same mph as yours.
If you didn't do it, take your sway bar off. I was able to get mid 1.6 60 ft. times without the sway bar.
index
index
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I used to run a similar cam to you on a 355.
-- Joe
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks, guys. I was very consistent also. The other times were 12.2098, 12.3762, 12.6663, 12.2160, 12.2048, and 12.2062 sec... I had a total of 5 ETs that would have qualified as my best ET ever.
Car: '87 IROCZ
Engine: 395 ZZ4
Milan Dragstrip (Michigan) is at 600' elavation,,, the temp that nite was about 75*F with moderate humidity, maybe about 40 to 50%.
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Linson
Oct 1, 2015 09:50 PM
