Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TBI problem
Old Oct 5, 2006 | 07:15 PM
scottz28's Avatar
TBI problem
i have a 1992 camaro rs with 305 TBI, the car i picked up for $400 dollars, very clean but didn't start, i replaced plugs, wires, and the rotor and it started right up, i also replaced the fuel filter too, but now i am having problems with the car running, it has a hard time starting, when it does start it idles rough and feels like there is a vacum leak or a missfire, ive checked all the vacum hoses and gaskets around the throttle body and have found no leaks, when i drive the car it hesitates alot when giving it gas, and the check engine light will come on every once in awhile, and gives a lean mixture code, i have replaced the 02 sensor, injectors, map sensor, fuel pressure regulator, fuel filter again, throttle position sensor, and still no change, then if i drive it for a while and then shut it down and let it **** for a little bit, and then try and start the car again, the car will start but then dies right away, and i have to keep pushing the gas to keep it running, i have took it in to get it looked at and they said it was the EGR valve, bu ti have replaced that too and still no change, so there went a waste of $90 dollars for nothing, so if anyone has any ideas, that would be very helpful to me
thanks
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
