Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
24 lbs injectors adequate?
Old Nov 28, 2006 | 06:49 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hello,
I'd like to know are 24lbs injectors sufficient to 355 vortec engine(hot cam+ported vortecs+stealth ram)or do it need bigger injectors?
Jari
Old Nov 28, 2006 | 08:49 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
24's should be fine
Old Nov 28, 2006 | 11:34 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Maybe. I was nearly maxing out my 24's on a 355 with TF heads, HOT cam, ported runners/base, and headers. With the HSR, I knew they'd be maxed out, since others had the same experience. It all depends on how much power you're making and how high the powerband is...
Old Nov 28, 2006 | 02:56 PM
z 28 jari's Avatar
Engine: 385
The engine that I have going to buy makes about little over 400hp at 5500rpm and over 400 lbs torque.Engine is dynoed with 850 cfm carb,1 5/8headers.So I'm not so sure that it makes a honest 400hp in "real world" situation. I looked that story "ram that tpi"where they have to lower fuelpressure at that iroc that they got a/f ratio right.They have 24 lbs injectors.Are 30 lbs injectors overkill to my combo?
Old Nov 28, 2006 | 04:35 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
If you can burn your own chips 30's should work fine.
Old Dec 5, 2006 | 07:02 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
24#/hr injectors should be plenty, but I would install an AFPR (adjustable fuel pressure regulator). Currently, I am running 24s in my 395 cu.in strker at 52psi. With this stroker, I am finally maxing out the injectors. So, for a 355 and no power adder, the 24s will be great at about 48psi fuel pressure.
Also, if you can not burn your own chips, I would definitely use 24s, 30s will cause too many ECM issues, I think.
Old Dec 6, 2006 | 04:05 AM
z 28 jari's Avatar
Engine: 385
I bought yesterday 30lbs svo's at ebay.Propably must go to aftermarket ecm(holley,haltec,megasquirt..),or buy another prom from lsracingchips.Mailorderprom isn't best solution,but I have no personal experience at promburning(-870ecm...)
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
Strick1
Sep 4, 2015 07:11 AM
