Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
What cam for 395 stroker & HSR?
Old Jan 23, 2007 | 07:42 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I followed vernw's post with great interest, obviously because I am considering swapping to the HSR. vernw settled on a 236*/242*/113*LSA.
My desirable is to keep the peak Hp NOT above 6200 RPM. Would this same cam be good for me? I kind-of like vern's initial selection of 230*/236*/113* LSA.
A few points that others may not realize:
1) I stick the 700R4 tranny in 'D', power brake to 2000 RPM, and floor it.
2) I am working with the weights & springs in the govenor to get the tranny to shift at 5800 to 6000 RPM with the current cam.
3) I have made a home made large MAF of 3.5" OD, which I am still tuning on.
4) I feel like I have not gotten every tenth of a second out of my SR.
Old Jan 23, 2007 | 07:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think that would be a nice cam and give similar numbers... your only 12 cubes more so i think you'll have similar power band as he will.
The TPI shootout on a 383 with that cam (the off the shelf 236/242 XE grind on 112lsa) made 501hp with a HSR at 6000rpms even. you should be around that with a 395. it made 497hp at 5600 and peaked at 501 at 6000 and held 495 at 6200. so you could even shift it at 5800 if you dont wanna go up over 6000 at all
Old Jan 24, 2007 | 10:50 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
One thing to consider - a single pattern cam. It helps lower the peak power point. I may have made a mistake by not going that route myself....
Jorlain
Oct 8, 2015 01:57 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
355tpipickup
Sep 4, 2015 05:32 PM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
