Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Intake for 383
Old Jan 28, 2007 | 10:58 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Intake for 383
I recently built a 383 for my 86. It's got Brodix IK180 heads, 1.6 roller rockers, and a Comp XFI Cam:
Operating Range: 1300-5300 RPM (1100-5100 with 383)
Duration Advertised: 252° Intake / 266° Exhaust
Duration @ .050'' Lift: 208° Intake / 217° Exhaust
Valve Lift w/1.6 Rockers: .477'' Intake / .472'' Exhaust
Lobe Separation Angle: 113°
I built the motor with the intentions of keeping the LTR design, and it currently has the stock TPI on top. My question is with the cam and heads that are currently on the car would it be more beneficial to keep a LTR design or go with a holley stealth ram?
Old Jan 28, 2007 | 11:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Holley Stealthram. Is that a flat tappet version of the Comp Cams XFI cam? You were being very conservative on you choice of parts. Should have a ton of torque.
Old Jan 29, 2007 | 12:30 AM
ht4100's Avatar
Yes, it's the flat tappet version. Yeah, I was conservative because I was planning on using a LTR design, and I use the car for the street, but I want it to be fast also. Just curious if my current set-up would perform better with a modified TPI or a Stealthram since the cost would be about the same to either route.
Old Jan 29, 2007 | 04:06 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
A Superam may a better choice for your combo.
However if your considering going to a better intake you really need to get a bigger cam as well. That cam is really small for a 383. And if your thinking of going with a better flowing (higher rpm) intake manifold, you should be looking for cams with duration in the 220+ range as well.
Im running a TPIS ZZ409 cam 226/226* with my Miniram 383 and the thing idles like its stock! LOL, I really wish I went with a bigger cam.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
