Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT-1 Intake conversion gasket?
Old Jan 29, 2007 | 02:45 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have converted a LT-1 intake to use on my 406 with Trick Flow 195 heads and I am having a hard time finding a intake gasket with small enough water passages to work with the intake. I was using a fel-pro 1205 gasket but the water passage in the gasket is larger then the water passage in the heads, and the gasket hole is too large and the intake does not cover the hole causing a water leak. What gaskets have smaller water passages that will work with the LT-1 intake conversion?
Old Jan 29, 2007 | 03:18 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I believe you need the standard LT1 intake gasket, which IIRC is a FP 1284
Or you could always build up the corners on the intake and have it re-faced....
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 29, 2015 10:47 PM
NinjaNife
Aug 23, 2015 11:49 AM
cRoe4
Aug 7, 2015 08:46 PM
