Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Post your HSR combos and dyno #'s / e.t.'s here please!
Old Sep 12, 2007 | 05:01 PM
  #51
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Post your HSR combos and dyno #'s / e.t.'s here please!
Not too many people on hear is using a 355cu with the HSR. Where are the 355 users? Let me see some results!
Old Sep 12, 2007 | 07:50 PM
  #52
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Stealthram.com has plenty of 355 users.
Old Sep 12, 2007 | 09:22 PM
  #53
vwdave's Avatar
Im close enough. Just a 40 over instead of a 30.
(The math works out to be ether 357 or 358. 358 just seems cooler to me and no one is going to bitch about a inch. )
Old Sep 13, 2007 | 04:43 AM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
um.... i went 13.24 at 101 tonight...... jeez this car loves cold weather.
Old Sep 13, 2007 | 11:51 AM
  #55
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
wow....and still stock cam and heads....those times are what most h/c 355 users are doing
Old Sep 13, 2007 | 01:34 PM
  #56
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i dont know, most cammed cars will do better than me, atleast trap higher. my car just uses suspension really well. 1.74 60 foot is better than my torquey TPI was. AWESOME
Old Sep 13, 2007 | 04:20 PM
  #57
Car: 92 Camaro
Axle/Gears: S60 373
what are your suspension mods? i was hoping for 12.00-12.15 area when i get my car to the track next week (hopefully). with heads and cam, you will be right there with me....
Old Sep 13, 2007 | 04:36 PM
  #58
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Originally Posted by 5.0 Eater
The one thing i have have found out is that our cars never sound as lopey as the enemy (fourth gen ls1's,or mustangs) due to the complications running dual exaust.(real dual, not just ugly rusty pipes hanging/dragging under our cars)sorry guys just a pet peeve
I have never had any complaints
http://s85.photobucket.com/albums/k7...t=b09aa63a.flv
Old Sep 13, 2007 | 08:17 PM
  #59
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i got full bolt on Spohn stuff... adjustable TA, LCA's with bracket, adj panhard bar from Hotchkis, and eibach prokit springs with adjustable tokico shocks. Not the BEST drag springs and shocks but they WORK!
Old Sep 13, 2007 | 09:26 PM
  #60
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Cold weather to HSR equals love......that's great times. Its time you get to porting those stock heads, milling them down, and installing that hotcam......I see 12's in your future.
Old Sep 14, 2007 | 05:03 AM
  #61
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Update:
Got some issues fixed but still running the shitty headers/y-pipe
357ci
9.3-9.8:1 compression
Holley Stealth Ram /w 38psi regulatar = 22lb injectors
170cc Edelbrock Performer RPM Heads
Comp Cams XE274 FLAT tappet 230/236 110lsa
Air fuel ratio is WB tuned 12.8 across the board.
Mustang dyno..
320rwhp@5800rpm 355rwtq@3800rpm
After 5000rpm the HP curve is pretty flat... 315~hp at 5000rpm to 5400rpm then bumps up to 320 around 5800 and falls on its face fast at 6000rpm. I think maybe my exhaust is really restricting it? I'm running Edelbrock headers which look like the old style with 1.5" and 1.625" mixed primaries. The Y-pipe is also 2.25" and is press bent.
Old Sep 14, 2007 | 10:22 AM
  #62
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Originally Posted by mike1986fyrbird
Update:
357ci
Mustang dyno..
Nice numbers....I think your y-pipe is a restriction. I would do nothing less than 2.5" with press bent. If you can get a 3" to work, go for it. 1 5/8" headers would be better or 1 3/4" for more top end pull.
Old Sep 14, 2007 | 01:09 PM
  #63
Car: 92 Camaro
Axle/Gears: S60 373
Update:
357ci
Mustang dyno..
that is very impressive numbers, especially with a 357.....more than my 385!
Old Sep 14, 2007 | 01:45 PM
  #64
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah that aint too bad at all on a mustang dyno which typically will read less than a dynojet.
i'd say shoot for atleast a 2.5-3 inch ypipe and atleast 3-3.5 inch catback. you proby could pick up 20 hp
Old Sep 14, 2007 | 08:32 PM
  #65
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
my bone stock 92 formula with 178,000 on the clock went 13.9 at 102 here in fl. If my hsr combo went only 101 I would give up on trying to go fast. I have a 383 in the car now stock ported l98 al heads, stock ported intake with slp runners, small comp cam 224 230 558 568 lift 1 3/4 long tubes 58mmtb 700r4 3600 vigalante triple disk 342 gear which went 12.2 116 on radials (not drag radials) on a 1.90 60 ft. (has gone 1.58 with stickys) It made 360 hp @5800 and 520 torque @3200. I am in the process of changing to the hsr now and will be selling my magical tpi intake set up as I have yet to see a car go this fast with a stock style set up. This is with no power adder by the way just in case someone tries to say it must have one. Have seen gains up to 5 mph in the quarter with the swap and 50 hp at the wheels.I am sure not that much in my case as I have made this stock turd make power with the mods I have done to it. I saw a good article with a 355 that made 301 with a stock set up and picked up to 358 with the hsr. Car went from 108 to 113 in the quarter. It had afr 190 heads and a zz9 cam. 226 226 and 525 lift. If I could remember where I saw the page I would list it. Guy had a great bunch of dyno comparisons of intakes and engines all in a 91 z28 mini ram vrs stock vrs hsr. Hsr was best out of 3. Also had a mini ramed 400 inch small block that made 420 @ the wheels 11.3 @ 119. It was a link on one of the diy tuning pages. Good luck.
Old Sep 14, 2007 | 09:09 PM
  #66
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well first of all thats hard to believe you went 102 bone stock. That is just hard to believe when LT1's make 50+ more hp and go 100-102 stock, some may hit 103.
And about that 101 comment, was that directed to me? If it was, why would i give up goin fast?? I'm sorry my car only went 97mph with TPI and i picked up 4mph with HSR....
Old Sep 14, 2007 | 11:25 PM
  #67
Car: 92 Camaro
Axle/Gears: S60 373
yeah......ummmm not calling you a liar but cant see a bone stock l98 going 13's.....especially at 102....
Old Sep 15, 2007 | 08:14 AM
  #68
jjvette's Avatar
Car: 89 vette
Transmission: a4
Don't let the mph bother you.
I used to run 12.80's at 102.xx in my highly modded 125,000 mile 350 TPI.
I remember going to a Vette car show/ dyno day and all the LS1 Vettes were putting down great numbers stock. Like 320 to my 253 rwhp. I got snubber badly. At the track was a different story though. I could wipe em off the line and they would never catch me. I was accused of running nitrous several times. Not much would beat me to the 1/8mi but after that ...another story.
Then I put on the stealth ram and it actually ran a slower et with a higher mph (13.28 @ 105). That was without tuning though.
Don't give up. Press on.
John
Old Sep 15, 2007 | 11:52 AM
  #69
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i think i'm in need of a drag radial and 3.73 gears.... just may not do a cam swap til next spring/late winter
Old Sep 15, 2007 | 12:06 PM
  #70
lt1z350's Avatar
I had really only paid attention to irocs at the track with tpi stuff when I had my 94 lt1 and most of them with bolt ons were around 98 mph. I do alot of street racing and most of that is done from a roll so mph is the winner on the street not e.t. I have a 392 ci lt1 now in the 94 that last time out had run 11.0 at 127 and I had to lift to make the 1 to2 shift because the 4l60e was giving up bad. It would sit on the rev limiter until I lifted then would make a slow sloppy shift. Any way I bought the 92 formula from the original owner with all paper work and history documented through out its life for 2200 bucks because the lt1 was down and I needed transportation. Being a racer I decided to take it to the track since the other was broke and all my friends were going. I took it in october to gainesville raceway and that was when it ran the 13.9 at 102. I turned up the timing a touch pulled the air filter and iced the intake because it had gone 14.1 3 other times and figured I could squeek it into the 13s with doing that. My 94 only went 13.9 at 97 I think when it was stock on drag radials. The only thing that had been done according to its history was a engine change by the dealer at 32,000 miles for a rod knock. When I melted the factory motor on a 225 shot I noticed it had brass freeze plugs and 4 bolt main caps. I dont know what they put in it I assume due to the caps a vette or truck block and would have assumed the same cam but dont know. I will try to dig up the time slip which means much of nothing with out seeing the car do it but I was just as suprized to see it go that fast esp the mph it made. It is a t-top no option car. No power, has a factory aluminum drive shaft dual cats (well had ) cloth seats. It weighs 3200 depending on fuel with out me in it. My 94 was 3450 with out me in it. I read dual cat firebirds were the highest rated at 255 hp due to airfilter setup and exhaust and dual cats. So a lighter car and only 20 less hp. I think the weight would make up the difference plus the l98 makes more torque than a lt1. I took my 2002 trailblazer 2 wheel drive and beat a 88 iroc 5.7 at the track on a 15.4 at 94 mph with my wife in the truck. The Iroc only went 15.6 at 92. So I see with a similar car running that number where 100+ out of another l98 seems not possible but I have no reason to lie. I put the intake on the car now up for sale since I am going to the hsr. If you run a stock style set up you have to siameese it to get power out of it. I have a article somewhere in a high tech where they took a stock 91 firebird and put a hsr on it and picked up around 50 at the wheels and it ran 104 in the quarter. That was with tuning it for the intake. I didnt mean to rag on the car I guess I was alittle harsh it should go quite a bit faster for the set up for sure unless you are way above sea level. Strange thinks can happen to make a car not run as it should but run right. When I first put at afr 190s and a cam in my lt1 it was only running 13.0 at 108 and I was crushed after spending all that money and only
picking up 2 mph over what it ran with all the bolt ons I had done. I had put forged pistons in it at the same time and the valve reliefs were not the same as stock and I was running a 600 inch lift cam and it bent every exhaust valve just a touch where they wouldnt seal up. Figured it out after 6 months of pulling out my hair and telling hypertech they couldnt tune a stock car and get it to go fast. (they did 6 different programs for it). I put in new valves and fly cut the pistons and put it back together and the car jumped right to constant high 11s at 114 to 116 depending on temp out side. I just expect alot from the intake swap from what I have been seeing and really that was the first car I have seen to run that slow with the setup on it. If it is a sd car the tune is killing it. Maybe I can help for my rudeness. Let me see you bin and I can recomend what I feel you need for it if you are intrested. Has to be lacking fuel or have a mechanical problem.
Old Sep 15, 2007 | 12:09 PM
  #71
lt1z350's Avatar
also sd cars were always qutie a bit faster than the mass air cars for the l98s
Old Sep 15, 2007 | 12:21 PM
  #72
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
The car is gonna go as fast as it is going. I have 89 MAF system and i have datalogged the car with the modified AUJL bin i'm using. the car is doing 128 BLM at WOT. cruise part throttle is about 128 as well. its alittle lean at idle and during first acceleration but thats not to big of a deal. i can maybe play with the timing again but i think its at its max for performance. I made 250whp. other cars making that power are doing 100-102 mph so i'm on par.
Your 92 formula doesnt sound stock to me if it had a different block. compression could have been different and so could the cam. I'm only about 1200 ft above sealevel. the DA on my 101mph run was 1800. when its hot out and 3300 ft DA, i went 99. Most L98's i have seen at my track (and i only seen a few) run mid high 14's at 94-95 in mostly stock form on street tires and stock trans. I rarely see thirdgens out here and the only ones i have seen were L98s so thats good. Another buddies 89 formula 350 with full bolt ons went 13.6's at 100 on street tires/stock stall in the summer.
It just seems like your car is not stock. Any way, you'll like the HSR. it will make abig difference
Old Sep 28, 2007 | 11:09 PM
  #73
Car: 92 Camaro
Axle/Gears: S60 373
in sig
Old Oct 2, 2007 | 05:43 PM
  #74
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
My 92 Formula bone stock internals with a hsr edelbrock shorties, underdrive crank pulley,160 stat, 2800 stall 3.23 gears and a 150 shot put down 384/420 havent taken the car to the track yet but it did go 12.3@109 when it put down 355/463 with the tpi on it. With the hsr the car pulled 5500 and was still making 350 hp.
Old Oct 2, 2007 | 08:27 PM
  #75
Car: 92 Camaro
Axle/Gears: S60 373
your car is living on borrowed time
Old Oct 2, 2007 | 10:03 PM
  #76
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
most cars seem to handle 150 shots well from what i seen
Old Oct 2, 2007 | 11:47 PM
  #77
Sprayed92's Avatar
Car: 92 Formula
Yeah that's what I thought but I've sprayed this thing over 75 times now
Old Oct 4, 2007 | 07:33 PM
  #78
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
Well, I am very bummed at my dyno run today, same cam for both dyno runs, stil lusing SVO-24# injectors, A/F ratio was 13.2
I know the 233/233 was weak for the Miniram so I am pretty certain that it is weak for the HSR as well,
NA Miniram = 385RWHP & 405 RWTQ
NA HSR = 385RWHP & 410 RWTQ
Old Oct 4, 2007 | 08:11 PM
  #79
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i didnt think you'd make more hp with HSR over the miniram but i wouldnt have been surprised if you made more torque since the runners are abit longer with HSR
Old Oct 4, 2007 | 09:13 PM
  #80
ol,rj's Avatar
Car: 86 vette
Engine: 406 single plane EFI
Transmission: TKO 600
Axle/Gears: 3.08
hey larry,
its not that bad!
after looking over both dyno sheets, I'd say you've gained 10 to 20TQ and HP over the miniram in the 4000 to 5200rpm range.
plus it didn't lose anywhere to the miniram.
I'd call that a gain!
RJ (yes I was there at the dyno pull)
Old Oct 4, 2007 | 09:16 PM
  #81
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
What dyno sheets? Need to post them.
Old Oct 5, 2007 | 06:10 AM
  #82
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
HSR Dyno Oct 2007
Miniram Dyno from 2004
Old Oct 5, 2007 | 06:20 AM
  #83
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Going to the Drag Strip this afternoon, Indianapolis Raceway Park
Old Oct 5, 2007 | 03:52 PM
  #84
jjvette's Avatar
Car: 89 vette
Transmission: a4
Good luck with that beast! Post the numbers!
John
Old Oct 5, 2007 | 06:01 PM
  #85
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
John
Crazy hot,, slippery track and bad luck,, I broke my accelerator pivot bracket on he first and only run........ too much adrenaline
2.2 sec... 60'
12.8 @ 114.9 mph
Need cooler air and better luck,, and a bigger cam
I'll hit the track one or twice again on a Wednesday night at Muncie Dragway
Old Oct 6, 2007 | 08:46 AM
  #86
jjvette's Avatar
Car: 89 vette
Transmission: a4
Wow! I can see by the 60' that traction was ugly! You gotta get that down to 1.6 /1.7ish. Yeah I'm thinking my cam is too small as well. It's the CC XR276HR- 224*/230*. lift is around .510. It peaks on the dyno @5500rpm.
John
Old Oct 6, 2007 | 10:32 AM
  #87
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
that cam is perfect for my budget goals lol ie cam only 155K miles L98 with HSR
For a built motor tho and miniram/hsr on a 355, i'd like a custom grind like Advanced induction 226/234. Local guy was doing low 12s at 116 on a AFR headed LT1 with this cam. Else i'd go with something like a 227/233 from combination motorsports or even the XFI 230/236. they all should make power by 6000rpms or so
Old Oct 6, 2007 | 01:34 PM
  #88
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Right now I am considering pulling this cam in the winter and upgrading to a 239/239,, ZZX cam
Old Oct 6, 2007 | 02:28 PM
  #89
Car: 92 Camaro
Axle/Gears: S60 373
John
did you finally get that dyno tune done man? why do you think it is too small? You are getting low 12's on a dyno tune that is not yet complete. plus you have some happy gas that you spray. I'd kill to hav your ET.
Side note-forgot that witha bigger engine my power band wil go down with the same cam....i was shifting at 6000 when i went to the track last week. Wonder if that had something to do with my disappointing numbers (along with my need for a bigger converter and gears)?
Any reason you think my cam wouldnt make power to 6000 on a 355? or is it just you really like the 230/236 cam?
Last edited by 89formula350b2l; Oct 6, 2007 at 02:29 PM. Reason: Automerged Doublepost
Old Oct 7, 2007 | 08:19 AM
  #90
jjvette's Avatar
Car: 89 vette
Transmission: a4
No tune yet. That is in the near future. It has been really hot here and I haven't had the ambition to go play. But it's coming as soon as it cools down.
I am not complaining about the e.t. although I was shooting for 11.50's N/A when I built it. Based on the dyno results my motor peaks at 5500RPM. I would like to see it up around 6000. Thats why I think I need a bigger cam. I guess a gear change would help get closer to 11.50's! The 3.07's really are a mismatch.
I am far from done with tweaking it.
John
Old Oct 7, 2007 | 11:22 AM
  #91
Car: 92 Camaro
Axle/Gears: S60 373
I thouyght about changing my cm when I went from a 355 to a 383 but for a couple hundred more $, I can throw that NX kit that you have on my car and it will be ALOT more beneficial then just a cam swap. Another member said it on here, "you wont find a magical 30 more hp from one off the shelf cam to anther. That is unless you have some seriosuly mis matched components."
There are two or three other members on here running 12.2x-12.0x with our engine combo's in a f body. So with that in mind, I think with a good tune you can get your target ET. Good luck man!
1984HO
Mar 19, 2021 11:59 AM
Hawk312
Aug 22, 2017 08:55 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Reborn756
Sep 4, 2015 03:42 AM
355tpipickup
Aug 29, 2015 10:47 PM
