Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
type of injector
Old Feb 7, 2007 | 11:04 PM
stevemicaelo's Avatar
type of injector
i am looking to buy some injectors.
i talked to the svo(ford) dealer in the area and priced out some 30lb red top injectors but then he asked me if they were ev1 or ev6?
i wasnt sure .
so i ask what do i have ev1 or ev6.
or can you suggest another injector.
383 putting on HSR need to buy injector thinking 30 LB
Old Feb 8, 2007 | 06:57 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
i wasnt sure .
EV1.
EV6 is the new round connector some of the cobra's and other fords use.
-- Joe
Old Feb 8, 2007 | 07:28 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yep thats correct,,, EV1
Old Feb 8, 2007 | 07:44 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
I'm using LS1 injectors with my Stealthram setup . I think they are around 28lb injectors .They're quite noisy though .
Old Feb 8, 2007 | 08:13 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
you can hear the injectors????
Old Feb 8, 2007 | 08:20 PM
wanta427's Avatar
Car: 1991 Z-28
yes . It sounds like a solid lifter car . I'm going to try raise the fuel pressure from 46lbs to 50 and see if that helps . If I remember correctly LS1's run higher fuel pressure
Old Feb 11, 2007 | 07:40 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
All LS1 cars run 58 psi fuel pressure, given that, they flow 26 or 28 #/hr. The '99s and '00 used the 26s, while the '98s, 01s and 02s used the 28s.
In our third gen cars, these 26s & 28s will flow about 22.5 & 24.5 #/hr, respectively.
Old Feb 20, 2008 | 08:00 PM
TKR Performance's Avatar
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
Re: type of injector
Did you have any fit problems with the LS1 injectors? I'm about to do the same swap and heard that the LS1's are shorter and may not fit my S/R. Any input would be greatly appreciated!!
Old Feb 20, 2008 | 08:23 PM
wanta427's Avatar
Car: 1991 Z-28
No problems on the fit on the SR. I also used them before in the stock manifold with no issues .
Old Feb 20, 2008 | 08:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
You need to be very careful here. The LS1 injectors in my '99 Camaro SS are 0.12" shorter from oring to oring. My L98 injectors measure 2.68", while the LS1 injectors measure 2.56"... Several poeple on this site have had huge fuel leaks using LS1 injectors. In fact, I read that SLP has stopped recommending using LS1 injectors in our TPI 3rd gen cars.
Twin_Turbo
Mar 14, 2016 10:10 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Hello, Michael
Sep 11, 2015 01:10 PM
92rsvortec350
Sep 10, 2015 10:54 AM
