Fuel Rails????
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Fuel Rails????
So I bought this intake off EBAY. I thought it may be interesting to experiment with. See if it gets higher RPM then the modded TPI. The only catch is it does not come with fuel rails. Supposedly Holley's fuel rails fit.
My question is: I was looking at the Edelbrock fuel rails, and I am not sure why they would not fit. Port spacing should be the same, and then I could create my own crossover and fuel lines with some -AN'
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
It should definitely pull more RPM's than a modded TPI. Fuel rails depend on manifold design. If you have the Edelbrocks, try them. If not I'd get the Holley's.
Car: 92 Z28
Engine: Boosted LSX
You could always buy 2 pieces of 18inch fuel rail stock and make your own.
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
just do a google search tons of places sell it.
Car: 91 Camaro RS
Engine: 355 Vortec
I believe this intake is obsolete, but it should use the same fuel rails as the Holley 9901-107 efi intake manifold. That would be the fuel rail kit 9900-172.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
They do appear to have the same height and style mount as the HSR rails.
I don't have a closer view but can get one if you need it.
The mount hole is right between the injectors, thats what caught my eye that they may be the same.
