Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
proper torque specs 4 vortec stealthram
Old Feb 22, 2007 | 12:33 AM
stealthrocz's Avatar
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
On the instructions it says 11 foot/pounds for a final step, someone else told me it should be the usual 35 f/p. So far its holding up with the 11 foot/pound as per instructions. Also I am using the factory intake gaskets with the silicone seals around the ports. Just took it for the first ride with the new engine, man feels good to drive her after a year n half. Any info will be greatly appreciated thanx
Old Feb 22, 2007 | 12:44 AM
Z69's Avatar
Z69
I was told stock vortec intakes & bolts will bottom out in the holes.
So 11 is ok.
11 may not be enough.
15 felt better on my carb intake. And they are less likely to come loose.
Edelbrock instructions say to use loctite.
Old Feb 23, 2007 | 07:39 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
yeah, its only 12-15ft-lbs. They are not perpendicular to the intake face, so they are applying alot more pressure than you think. The bolts are only 5/16" that is usually around 22ft lbs for a grade 5 bolt, but I guess they only need less due to the angle, and torque really just to load the bolts correctly.
the bolts don't bottom out (well, yeah, if they are too long), but if you are using the factory type gasket set/bolts, they should have a metal insert to prevent over tightening. Loctite is an OK idea, but remember that will reduce the friction and make your torque value even less before it hardens.
Old Feb 24, 2007 | 12:23 AM
Car: 87iroc
Right on thanx guys I just wanted to make sure as it is a new engine and didn't want to have any problems. The intake gaskets are OEM w/ the rubber seals around the ports and I have seen some fel-pro that looked pretty thick, should I be using those for the stealthram?
z 28 jari
Sep 14, 2021 10:03 PM
Jorlain
Oct 8, 2015 01:57 AM
sandman92084
Sep 12, 2015 10:27 PM
angel2794
Sep 8, 2015 06:22 PM
