Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
what is this? do I need it with the HSR?
Old Mar 9, 2007 | 06:26 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im sure you guys know what this is...it was on the back of the plenum of the TPI....I followed it and one end goes to the cruise control vaccum thingy....I think..I dont know where the other end goes..it ends up in a big gaggle of wires and stuff..do I need this with the HSR? or can I just remove it?
Old Mar 10, 2007 | 11:41 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
that looks like a vacuum line for a regulator. I had one like that on my TBI for the Adjustible Regulator that had a vacuum line. maybe the same thing. JUst hook up what the user manuel says and that all you should have to use. If you have the C950 most of the wires in the engine bay aren't needed anymore. My 2 cents
Old Mar 10, 2007 | 01:07 PM
nah Im not ueing the C950 management system......I had TPI and Im just hooking up what wire I have from that....the vaccum line Im showing was used on the back of the TPI plenum...one came off the regulator and went to the back of the plenum and the one Im showing went to the back of the plenum also.......but with the HSR there is only one connection for the line comeing of the regulator.
i hope im making sense.....
Old Mar 10, 2007 | 07:00 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
That is a check valve.
It is used for the cruise control and I think the other line goes to the HVAC inside the car.
Old Mar 10, 2007 | 09:02 PM
do I need this? you mean if i remove it I wont have cruise control?..how would I hook it up if there is only one vaccum connection on the back of the HSR?
if I just remove that valve and connect the 2 lines together will that work? or doe it need vaccum? for the plenum?
Old Mar 11, 2007 | 12:40 PM
It needs vacuum.. thats how it works.
If you don't have those lines hooked up cruise control wont work. The HVAC wont go to the off position and will always be defaulted to the defrost/vent setting and you will not be able to change it.
What do you mean there is only one vacuum connection on the HSR? There is about 5 ports total on the hsr. You only need one port for this check valve and if none are open use a T fitting from the fuel pressure regulator/map sensor vacuum line or drill and tap another hole to put another fitting in.
Old Mar 11, 2007 | 01:00 PM
yeah..i just figured that out..I have like 2 holes in the back plugged...I can just unplug one and put a fitting on there like I got for the fuel reg. and then I should be good to go....
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
