"So I added the HSR to my otherwise stock 350..."
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
OK, the title for this thread might be slightly misleading, because I haven't installed my HSR yet - but I have a question.
It seems like I've seen more than a couple people state that they've added the HSR to an otherwise mostly-stock L98 car, & it runs great, no issues with idling, driveability, etc. But my understanding is that on our cars, the computer relies at least partially on the EGR system, which the HSR has no provisions for.
So what gives? Why do the cars (apparently) run OK, even without the EGR?
(Yes, that was one of the things that's kept me from installing it yet...)
Thanks guys.
Thanks guys.
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Re: "So I added the HSR to my otherwise stock 350..."
I would suggest at a minimum to disable the EGR in the ECM, I know you can have this done when you have a custom chip made or you can DIY. Also I should have some more info next week on my setup.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
The reason the EGR is not an issue is because there is a temperature sensor at the base of the EGR valve. Once that temperature sensor reaches the proper temp, it tells the computer "Ok I'm warm enough now so you can enable EGR function" If you have the sensor disconnected or if it does not ever reach temperature, the computer will never enable the EGR function and it will not set a code. I did this for years on my 305 with aluminum L98 heads. aluminum vette heads do not have an exhaust crossover, so the intake never warms up and the sensor never reaches proper temp. That is why guys swap to the HSR or swap to non-crossover heads and do not have EGR issues.
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
so i can untie the egr temp sender from my wiper motor?
(On a serious note, I can't wait to see how your car runs - wouldn't surprise me too much if you got low-13s/high-12s even at this altitude!)
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
I'd love to come over and help you install yours if you will loan me your fuel adapter fittings untile mine come in. (check mhtg pm's)
Car: 86 IROC
Engine: 383
no problem, thats what the boards are for.
LT1Formula
Nov 16, 2015 01:13 PM
