Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
whats up with this? hows this happening?
Old May 16, 2007 | 09:06 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
ok..dont know if you guys been readin my threads about my timing issues..but anyways, Im in the process of fixin an oil leak on my front balancer seal and having to remove the dizzy to fix the timing...when I removed my plenum I found this?...gas all over the back gasket and in one of the bolt holes....what caused that? loose bolts?
heres some pictures...I also removed my plugs and they all look perfect Im guessing...SO I havnt been running lean or rich..right?
see the different color of the front vs back gasket? the back one is soaked
gas all over the gasket
in the bolt hole
all over the bottom of the plenum
plugs look good, right?
Old May 17, 2007 | 12:04 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Re: whats up with this? hows this happening?
The liquid in the bolt hole almost looks like tranny fluid, as for the gas build up on the gaskets I had the same thing along with the plugs looking fine, but my gas build up was from the spark plugs not being long enough to properly ignite the A/F mixture. My only suggestion right now would be that maybe the injectors are allowing more fuel on those cylinders and since the those cylinders are the first place the fuel goes and the last place it leaves maybe you are seeing a fouled injector, if your injectors are new then never mind that comment. I will continue to ponder........
Old May 17, 2007 | 08:37 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Looks like oil getting sucked out of the PCV..
-- Joe
Old May 17, 2007 | 08:50 AM
what do you mean?
I am using the fitting under the plenum for the PVC? ..is that a problem?
where is that gas coming from?...since you mentioned the PVC...Im assuming that is gas/oil mixed.....
I just spoke with a friend of mine here at work...and he would think there would have to be some sort of negative pressure to suck gas back up ...seeeing the pleum is just for air intake to shoot it down the runners. ...
Old May 17, 2007 | 10:10 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Try your fuel pressure regulator, could have a torn diaphram leaking gas into the vacuum line.
Old May 19, 2007 | 09:26 AM
jjvette's Avatar
Car: 89 vette
Transmission: a4
That is oil coming from the PCV valve. Put some kind of filter in there to slow/stop it.
jhawkeye
May 25, 2022 06:33 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
CORV3TT3
Aug 23, 2015 11:26 AM
BurlyChev
Aug 16, 2015 09:08 PM
