No low end tourqe
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
No low end tourqe
Hi!
I am a little dissapointed about my low end tourqe after installing the HSR.
Is it normal to feel such a difference before 3000rpm,or can it be a tuning problem?
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Re: No low end tourqe
The HSR being a short tunnel ram setup will sacrafice low end torque for high end power. How much of an exchange is felt depends on the rest of the motor, exhaust etc. Tuning can help but this is mainly the nature of this intake.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
Maybe i chould have gone for the slp,but its not that bat but it really feels weaker than before,i havent run it over 5000rpm yet so maybe there the big difference are?
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Its probably running rich down low because there is less air entering the engine in the lower rpms. That will cause a loss of power on its own.
Check this out. Not much loss in torque but a huge gain in HP. HSR is a great intake.
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
where did you get that it looks like it is in a book or magazine? thanks Daniel
novaderrik
08-10-2015 12:44 PM
