super ram fuel rails
does any body make a bigger fuel rails or does any one know how much flow the stock one max out at ?
im planning on making big hp but i might change intake if i cant get enough fuel.
Re: super ram fuel rails
ok how bout this what the most hp that some one has made from the stock injector
im planning on making 1000+ , and i have a super ram laying around but im unsure on weather i should use it or go the single plane route.
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
bodie,
For that much horsepower you are venturing into carburetor country. Im sure you can force the issue if you really want to use the super ram ie turbo, nitrous, surpercharger. Depends on how much you want to spend and how much patience you have. Just my
Rabi --->>C
Rabi --->>C
well im building a twin turbo motor and was thinking the superram intake would look for a better install, but if have to ill just get a single plane intake, the only thing keeping from using the intake the flow of the fuel rails, hell i even had the intake modified and ported to a 1206 gasket.
Car: 88 Formula 350
Bodie,
That type of power is possible with a supper ram. Check out this site;
http://www.grapeaperacing.com/GrapeA...maro/index.cfm
Rabi C.
Rabi C.
Car: 92 Z28
Engine: Boosted LSX
703 whp 723 ft. lbs torque! some good reading. You DON'T need to swap to a carb...
http://www.theturboforums.com/smf/in...?topic=61219.0
