super ram/ injectors
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i recently had a head gasket go bad to while I had the car stripped down I decided to install a ZZ4 and Brodix IK 200 heads. Now the car is running like hell. No Power, 2 clylinder down. I have spark to all 8. I read in an old post that I couldn't mess up wiring the injectors. I was told that they fire in banks. all 4 black with green tracer fire at the same time on the passenger side and all black with pink tracer fire on the driver side. So as long as I had the pinks on the drivers side and the greens on the pass side it wouldn't matter in they didnt go back to the org spot if I was off????? Is this correct???? Or is every injector to be wired with a certain wire?????
Don't want to pull my super ram if it doesn't matter!! thanks alot guys!
Re: super ram/ injectors
Did you actually "re-wire" each injector clip? You should have a green, and pink to each injector clip. Since it is a batch fire, you can take the first injector clip, and exchange it with the second one, and it would not matter, but from your post, it sounds like you had done some rewiring.
Car: 89 Formula 350
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
what kind of tune are you running? I'm assuming you had a chip burnt for this?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am guessing that its all in the distributor. And the timing & tune at idle.
When you set the spark advance at idle, did you unplug the EST wire for the dizzy? And are you sure you got the dizzy in correctly?
