Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
pro products sbc efi manifold
Old Jun 27, 2007 | 12:26 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I recently saw that Professional products started carrying an efi maifold (52038 and 52039)for sbc that is quite affordable:
http://www.professional-products.com...uctSBchevy.php
I found that the satin manidold is 200 and the polished is 245. rails for them are 100. This puts it below the cost of a HSR. All you would have to do is to make an intake elbow with a square bore spacer to bolt to it. It is basically a Hurricane manifold with machined injector bosses. I have owned the Hurricane and found it to be a good intake-I converted it fuel injection then sold it.
Anybody have experience with it yet. I might try this if I build my 400 this winter.
Old Jun 27, 2007 | 08:38 AM
bodie's Avatar
Re: pro products sbc efi manifold
damn that looks good, and cheaper then the edelbork victor efi by at least 100
did a quick search and found a retailer
http://www.northernautoparts.com/Pro...ProductId=2802
Old Jun 27, 2007 | 09:36 AM
gbodybilly's Avatar
Car: 86 MCSS, 03 S10, 99 MX-5
Engine: 5.7, 2.2, 1.8
Transmission: 2004R, NV1500, Miata 5-spd
Axle/Gears: 3.73, 4.10, 4.30
I wonder if they make a Vortec version - that'd make for a real bang for the buck!
Old Jun 27, 2007 | 05:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
One of the members on here that I have meet is a supplier of professional producs. That is where I got my prices from. I will end up buying from him as he is a supporter and member of this site. This ends up being at least $150.00 than the HSR with fuel rails. I am sure flow is quite comparable.
Old Jun 27, 2007 | 07:50 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I'd bet $100 that those pieces are actually edelbrock manifolds. They all look identical to edelbrock stuff, and they have the same product line. I am guessing they are somehow getting their hands on raw cast edelbrock stuff and selling it that way. Kinda like how Accel and Edelbrock share the same TPI base.
Old Jun 27, 2007 | 08:00 PM
bodie's Avatar
tibo who is this member ?
i just found out the the SR i got wont work, and are gonna go single plane.
Old Jun 28, 2007 | 12:43 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
PM me if you are interested in any Pro Products items.
Old Jun 28, 2007 | 01:18 PM
JimmyDavidson's Avatar
Car: 1984 Camaro z28/SC
Engine: 355
Axle/Gears: 9bolt 3.89
Nope, they are VERY similar, but are NOT the exact same casting. They are a cheaper Chinese manifold(even says on the bottom). Im not saying that they are bad or anything, because I have a Pro Products manifold and it works great. I like how it has a rear water ports to cross the water and keep the motor a little cooler. Just hook the rear ports to the fronts, with braided lines(or virtually anything) They will probably need a little port matching though, because the ports are not always 100% correct, but still a good price.
Old Jun 28, 2007 | 03:47 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
It's not edelbrock, I have the edelbrock victor EFI and there are differences I can see just in the small pic there on the site, primarily the injector mount bungs, location of them, and the rail mount style.
Old Jun 28, 2007 | 04:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
They are less expensive and made in China. They are a good manifold. they are not the super cheap sand cast molds. I have owned 2 or three of their manifolds as well and was happy with all of them. Some small port matching is needed, otherwie, alright.
Old Jun 28, 2007 | 05:47 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
I had an edelbrock manifold to go on my engine with vortec heads, and the engine builder said no go out and buy yourself a professional products crosswind plus for the vortecs. We find they flow better then the edelbrock ones . It was not a sales pitch either because he was not selling me the intake and he knew I already had one from edelbrock. He was not the first engine builder recommended these intakes either .
Old Jun 28, 2007 | 10:06 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
wow I stand corrected. thanks for the info guys.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
dimented24x7
Sep 6, 2015 03:51 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
