Where is your coil mounted
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Re: Where is your coil mounted
I bolted mine to the firewall. Same place i had it with TPi to allow easy access to the distributer.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
here you go...this is what your looking for.....
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
i used my stock coil mount hanging down off the cowl. similar to the above pic. it hangs between the dipstick and dist. cap though.
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
i relocated mine to near the master cylinder to get that area of the engine bay a little less cluttered
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Wherever you mount it, make sure that it has a clear path to the motor. The spark energy needs to make a complete loop back to the coil. If you make it easier, there is less ignition noise and less stress on components.
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
