Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Holley Stealth Ram
Old Sep 9, 2007 | 02:32 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Holley Stealth Ram
Can a L98 throttle work on a HSR?
Old Sep 9, 2007 | 03:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Holley Stealth Ram
yes, L98 throttle body bolts to the HSR just fine. even the stock bracketry for the cables.
you may have to adjust the linkage abit for clearance around the holley fuel rails, and adjust the linkage so the throttle can close 100%. mine wasnt closing all the way and left 1000rpm idle. i just ground out abit of the oval shaped sliding bar thing that opens the throttle blades. now it closes just fine
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
