Min Ram for Vortec heads
Car: 89 Formula
Transmission: TH 700R4
I have the edlebrock E-tec (Vortec style heads). I really don't know much abuot the mini-ram intake--who makes it and is there a version to bolt up to my heads?
thanks
thanks
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Re: Min Ram for Vortec heads
I dont think that you can use the vortec heads with the mini ram. TPIS makes the mini ram so if you have any questions about it I would give them a call.
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
Check out www.tpis.com for the MiniRam. There website sucks donkey *****
, but they list one for fast burn heads. Someone please correct me if I am wrong, but I believe Fast Burns are Vortec style.
, but they list one for fast burn heads. Someone please correct me if I am wrong, but I believe Fast Burns are Vortec style. Member
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
871LEIroc,
If the mini ram doesn't bolt on to your heads then you can try the ram jet. Thats supposed to be a nice piece. GM makes it. Check it out.
http://www.gmhightechperformance.com...ro_rs_feature/
http://www.carcraft.com/howto/56398/index.html
Rabi C.
Rabi C.
Last edited by onfire; Oct 14, 2007 at 02:11 AM. Reason: added a wrong link :D all fixed
Car: 88 Formula 350
With a cam of 196/206 and 431/451 and comp at 9.4, it delivers a pretty flat torque curve all the way up to 4500 where it starts to slowly back off. Probably because of that small cam. Not bad though.
http://www.gmperformanceparts.com/En...9120&engCat=sb
Rabi C.
Rabi C.
If you read through TPIS's site, you will find that the MiniRam has enough metal to actually cover the Vortec intake ports, unlike alot of other intakes; and if you tell them that that's what you're putting it on, they will CNC the ports ¼" higher (or whatever it is) for you and drill the other holes. For a fee of course.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I bought a miniram III from TPIS for my L31 heads. They fit the fast burn and vortec ports, but you have to re-drill the L31 intake pattern for older style bolt pattern.
No problem, I used old intake gasket for pattern and drilled on a good press. Heads off engine, of course.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Call them and ask them is they have any 'blemished' intakes. I bought my miniram 'blemished' for $300 bucks less than the regular price and the only thing wrong with it is the 'TPIS' logo is have readable. Intake still works the same.
Car: 92 Trans Am
Transmission: 4L60
Hmm, I will have to try that! I would have never even thought of it on my own
Engine: LB9
Axle/Gears: 3.55
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
