Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Ram Jet and hood clearences
Old Oct 23, 2007 | 09:08 PM
Kawtipping's Avatar
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
First off, I tried a search but came up with nothing. I know from reading on here that the Holley Stealth Ram does not clear a stock TA hood (without cutting braces). After digging, I see that the GM Ram Jet is 3/4" shorter. So that leads to the question...Has anyone used one with a stock 3rd gen TA hood? Does it clear without a problem? Thanks all.
Old Oct 26, 2007 | 01:29 PM
Ronny's Avatar
Re: Ram Jet and hood clearences
on gmperformanceparts website is a catalog.pdf. i tried to DL but took forever. I would fire them an email.
actually i would use the victor JR EFI manifold(shorter) with an accel TB unit.
or if still wont fit (i think it would be close) use a weiand accelerator low profile and have a machine shop weld in the bungs. that will fit no problem
Old Oct 26, 2007 | 01:38 PM
Kawtipping's Avatar
Car: 92 Trans Am
Transmission: 4L60
Thanks Ronny, but I am trying to keep some resemblance to a TPI set up. After looking at hood heights and all the other fun stuff, I realized that I never thought about what style of intake/head it was. The Ram Jet is for Vortec heads...something that I do not have, nor am I willing to change to. So it looks like either an after market hood and a Holley Stealth Ram, or keep my car "looking" stock and give a nod to TPIS's Miniram. It is only money right? Either way, I want to decide soon. Right now the car hits a brick wall at 3000 rpm...at only 290hp!! Needs more air, and I am not going to band-aid it with "high flow" runners and plenum.
Old Oct 26, 2007 | 01:41 PM
Ronny's Avatar
mini ram.
Old Nov 3, 2009 | 04:15 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
I figure after two years, you've either given up or found out for yourself... But my ramjet manifold cleared my stock formula hood (after a few swings with a hammer). The bracing has to be moved or cut, but not very much.
Linson
Oct 24, 2025 02:00 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
mr z28
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
