Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR adjustable FPR
Old Sep 7, 2009 | 08:00 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
HSR adjustable FPR
i have HSR fuel lines and AFPR, install instruction says that i need to connect vacume form intake manifold to AFPR. My car runs with no problem without pluging in this vacume line. My question is what is this for anyway ??
Best reagrds
Old Sep 20, 2009 | 07:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HSR adjustable FPR
Adjusts fuel supply in relation to engine load by changing fuel pressure .
With a stock TPI regulator
At idle ; hi engine vac gives 39 psi pressure.
WOT; low engine vac gives 43psi
Old Sep 20, 2009 | 07:31 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Old Nov 3, 2009 | 03:28 PM
MADMAXGTA's Avatar
Car: 89 TTA
where did you get you afpr? mines non-adjust id like to upgrade thx
Old Nov 4, 2009 | 02:15 AM
WASyL's Avatar
well i got it with these fuel rail kit for HSR: http://www.summitracing.com/parts/HLY-534-186/
best regards
Old Nov 4, 2009 | 03:46 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Also the Kirban unit...
http://www.kirbanperformance.com/pro...R+%236547.html
The HSR FPR is the same one as used on GNs. I had the famous Holley FPR failure and hit up vatozone for their 29.99 special until the Kirban one came in. Bolted right on (which was nice in a pinch because it was a daily)
Old Nov 4, 2009 | 04:09 PM
MADMAXGTA's Avatar
Car: 89 TTA
thx thats a nice peice.
Old Nov 4, 2009 | 07:36 PM
jonarotz's Avatar
Car: 91 Z28
I have a slightly used adjustable one if you're interested. It doesn't leak or anything I confirmed with a vacuum pump.
Old Nov 4, 2009 | 07:38 PM
MADMAXGTA's Avatar
Car: 89 TTA
possibly,got a part# and a price?
Old Nov 4, 2009 | 07:45 PM
jonarotz's Avatar
Car: 91 Z28
pm sent
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
