Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
svt lightning tb on a mini ram???
Old Oct 29, 2007 | 10:29 AM
1dopehat's Avatar
Car: 1990 iroc sunday driver
Engine: 350 tpi
Transmission: auto
Axle/Gears: stock g92 stuff
ok so i dk if anyone has ever done this or ever thought about it but on the ford lightning tb there is a single blade butterfly rather then having two...is there anyway to make it work with the 90 iroc tpi computer harness and mini ram intake??
here is a pic of the single blade tb for the lightning...
Old Oct 29, 2007 | 11:37 AM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Re: svt lightning tb on a mini ram???
why dont you just use a monoblade from as&m?
Old Oct 29, 2007 | 12:40 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
The bolt holes are different than a LT1/TPI throttle body....I saw a pic of it one time b/c I was thinking about it and changed my mind.
Old Oct 29, 2007 | 12:53 PM
AC's Avatar
AC
Car: Used to drive a camaro
Alum spacer/adapter to fit the TB onto the upper intake? I'd think you'd only need say 1.5" thk adapter to accomedate both sets of bolts??
Old Oct 29, 2007 | 01:02 PM
Guest
Guest
Posts: n/a
Yea, for the cost of that thing call AS&M and order a monoblade.
Old Nov 5, 2007 | 06:59 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
That accufab TB prob cost just as much or more then a monobloade that would bolt right to your miniram. A twin 52/58 MM will do most people just fine.
what are you building that you need 1300 cfm for ?
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
mfp189
Sep 27, 2015 09:25 AM
09ave
Sep 7, 2015 06:03 PM
