HSR GMHTP Link Help
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
HSR GMHTP Link Help
Hey guys,
I havent been able to find a link to the link in GMHTP for the Holley Stealthram, and will be doing this conversion, and need a little bit of a guide to make sure I dont do anything wrong when I switch from a large cap to small cap dizzy. Never been good at wiring, and maybe someone can gimmie a part number or schematic for the switch.
Cheers,
Brett
Cheers,
Brett
Re: HSR GMHTP Link Help
GMHTP only put part two on their site. Part one was the detailed installation, but here's part two. I've noticed some of the older links don't work anymore.
http://www.gmhightechperformance.com...roc/index.html
This is what I used,, but it was a lot less than $45 then.
http://store.summitracing.com/partde...5&autoview=sku
You can make your own if you don't mind splicing in the Small cap distributor pigtail
http://www.eficonnection.com/eficonn..._pigtails.aspx
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
