Seriously Lean after Intake Swap (LT1)
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
I've just done an LT1 Intake converison on a 85 Corvette and now i'm seeing a seriously lean BLM when logging. The car stumbles on load and mid-heavy throttle.
I've had an ignition problem which seemes to have been cured by replaceing the module in the camaro distributor. At least its not come back yet....
I'm seeing BLM's of 150-160 when loaded up, 128 on idle tickover. Fuel pressure has been adjusted up to nearly 50psi with very little change. I'm also showing 4-6deg of Knock on load.
I'm now stuck at the point at that I don't know if its an ignition problem causing the lean readings, or being so lean that its not stubbling.
Tomorrow I will try and get my Wideband installed to get a better idea of whats going on. I think i'll also burn a chip with LOTS more fuel to see if that makes a difference?
I've never read that people have had to do this much mapping just to get the car running right.
Any advice greatly appreciated!
Heres some history on the car, its a 1985...
Main:
1984 Block with Forged Pistons
1987 128 Alloy Heads
1994 LT1 Intake manifold converted for SBC Gen1 Heads
204/214 @.50 - Summit Cam
Ignition:
1987 Camaro Distributor and Coil Pack
1992 7730 Speed Density ECM
New Rotor
New Leads
Fuel:
1985 Fuel Pump
LT1 Fuel Rails
1992 TPI Fuel Injectors
Adjustable Fuel Pressure Regulator
Main:
Ignition:
New Rotor
New Leads
Fuel:
1985 Fuel Pump
LT1 Fuel Rails
Re: Seriously Lean after Intake Swap (LT1)
Start there. Throw those Multecs in the trash. I'd suggest starting out with 24# injectors from the newer Frod cars & trucks, the little thin-body light blue ones (make sure they have the right connector); you can buy them all day long on eBay. These are the 4-hole Bosch units. This type here http://cgi.ebay.com/ebaymotors/24-LB...em180211930699
They are SO CHEEP if bought used, and so popular, that you've got nothing to lose even if they don't work right for you.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It appears it was the map sensor from this post:
http://forums.corvetteforum.com/show....php?t=1929792
-- Joe
-- Joe
1992 Trans Am
Aug 8, 2015 08:16 PM
