Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel Pump Fun
Old Feb 19, 2008 | 05:22 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Fuel Pump Fun
Right now I am buying up the last of the parts I need to piece together my own EFI system. My camaro is originally carbed and right now it has a mechanical pump on it so I am assuming it has the carb tank in there (note: if my assumption is wrong, then I will have nothing to worry about). Does the carburated gas tank have the necessary provisions to run an in-tank fuel pump in the pickup assembly? If not, can I run an inline pump right after the line comes out of the tank? If anybody has pictures that would be great because I am thinking of possibly replacing all my hardlines with 3/8" stainless hardlines.
Old Mar 7, 2008 | 04:02 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Fuel Pump Fun
I don't know for sure but I would expect that the standard fuel pick up could be modified to accept a fuel pump. The tricky part would be getting the electrical connections to run the pump in/out of the tank. I'm would also expect that the tanks are the same (carb vs EFI) and you could swap out a pick up assmy out of a EFI car. But your idea about the in-line pump is probably the easiest. As far as stainless lines are concerned, it may be nice but I think it's overkill.
Old Mar 13, 2008 | 08:46 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Fuel Pump Fun
Just get a EFI sender out of the junkyard. Some things are just not worth making, if for anything else safety reasons.
-- Joe
Old Mar 13, 2008 | 11:03 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Re: Fuel Pump Fun
If you have the option to use an in-tank pump, do it. Fuel starvation issues suck.
-Dave
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
92camaroJoe
Aug 13, 2015 06:07 AM
