Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
What are these?? pics inside
Old Feb 23, 2008 | 03:56 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. My car is an 86 TA but the harness is out of an 89. I recently hooked up a good battery to test the fuel system for leaks, but I have no power. The distributer is out and unplugged as well as the starter, however I attached the starter power wires together. there are these two connectors at the rear pass side valve cover that i have no clue what they go to. Heres the pic below.
Old Feb 23, 2008 | 06:20 PM
Pocket's Avatar
Car: 91 Trans Am
Re: What are these?? pics inside
HVAC harness plugs
Old Feb 23, 2008 | 08:17 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Ok, which means they won't affect the no power problem whatsoever. So does anyone have any recommendations on relays to check, or whether the distributor has to be plugged in for it to work or not? Also, would the starter have to be there? I connected the three starter power lines, so i figured it would be fine. Cars been off the road for 2 long years, and i'm really anxious to get it goin again!
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
mud runner
Nov 2, 2015 07:30 PM
64Chief
Sep 12, 2015 08:05 AM
gt4373
Sep 9, 2015 10:29 AM
