Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 Intake Conversion = Engine Failure!?
Old May 16, 2008 | 03:57 PM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
I'm very tired right now, but after tearing down my block and taking it to a specialist here in the UK it looks as if my LT1 Intake Conversion has cost me the engine.
Gen1 Flat Tappet, 2pc Rear Seal...
To cut a long story short, it looks as if the distributor hole wasn't 100% perfect. Although there are no grinding marks on either Distributor Gear or the Cam gear something was making the Cam "walk" backwards/forwards.
The end result is I've got a snapped timing chain, every tooth broke off of the Crank sproket... and the casting behind the Cam sproket has been chewed away and groved. The sproket must have been grinding away at it.
I'm getting the casting re-leveled so I can use the block again, but I'm VERY concerned about using the LT1 Intake manifold again. I'm converting to a Roller Cam, retro fitted with Comp Cams Retro Roller Lifters but I don't think thats going to make any difference.
Old May 17, 2008 | 05:10 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: LT1 Intake Conversion = Engine Failure!?
did you have a cam button or some other means of preventing the cam from moving? the distributor being slightly off shouldn't have caused that. they used to mount them straight up on the modded intakes till it was realized that it was creating an oil leak.
Old May 18, 2008 | 01:31 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
if the cam gear or dist. gear have unusual wear patterns on them or chunks taken off the gears i would not suspect the machining of the intake to be the cause. does the cam have unusual wear on the rear journals or are the rear cam bearings showing excessive wear on them compared to the middle and front? were your timing gears lined up properly? timing chains do fail!
i hope you do not have any other problems below,put her back together use a cam button and let her fly.....
Old May 18, 2008 | 07:04 AM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Axle/Gears: 3.75
I will check the cam when I get a chance. I couldn't see anything obvious though. I don't know anything about the timing gears as I'd never been into see. It seems strange that I've put probably 6,000 miles on this engine personally, and only 500 since the LT1 intake?
I'm converting to a Hyd. Roller cam with retro lifters, cam button and torring bearings. I hope this will stop any further problems.
Old May 18, 2008 | 05:32 PM
Car: '88 Trans Am
Engine: 5.7L TPI
i really think it was coinsidence,the parts you listed are good what about a new CLOYES double roller chain?
Old May 19, 2008 | 02:18 AM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Axle/Gears: 3.75
I've gone with a JEGS double roller and 9 keyway torrington bearing timing set. I've not heard anything bad about the JEGS stuff so I hope it will be OK
Old May 21, 2008 | 09:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The block aligns the distributor. The intake adjusts the depth. If the distributor drops into place and the wear area on the distributor gear is centered (where the cam & distributor gear mesh), then it is OK.
A flat tappet cam has the lobes ground on a slope (front to back). This pulls the cam toward the rear of the engine and spins the lifter. The lifters are also crowned on the bottom.
RBob.
Old Jun 3, 2008 | 10:13 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Was the thrust plate loose or even on there? I remember someone that rebuilt an engine without putting the plate on. Caused some severe damage.
Old Jun 4, 2008 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thrust plate not required for a flat tappet. Wouldn't fit the cam or block anyway.
RBob.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
