Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
AFPR vac / boost reference?
Old Jul 13, 2008 | 08:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have a Aeromotive 13301 AFPR (new ) mounted direct to rail as mentioned in other HSR post.
Ran today with gauge hooked up. Set at 45psi.
Without vac connected holds at that pressure when reved; no pump or supply problem.
However when vac connected pressure drops at idle as expected but drops further when reved , no load out of gear( lower vac ).
confused:
Any comments
$750 L98
Feb 1, 2025 02:25 PM
Mark_ZZ3
May 24, 2018 01:02 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Dragonsys
Sep 25, 2015 03:51 PM
