Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Anyone tried this?
Old Sep 30, 2008 | 08:42 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
Anyone tried this?
I was wondering if anyone tried this. I've been thinking of something like this ever since I saw IRTBs.
http://holley.com/9901-101-1.asp
http://holley.com/9900-171.asp
http://holley.com/9900-172.asp
Old Sep 30, 2008 | 08:51 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Anyone tried this?
Yes..
https://www.thirdgen.org/forums/alte...e-intakes.html
-- Joe
Old Sep 30, 2008 | 12:32 PM
miner's Avatar
Car: 88 Iroc-Z
Ok, thanks.
I was wondering if a modified carb manifold would work for the manifold. I could probably get a used manifold for a lot cheaper than $350 that one. My other question is is it possible to modify a carburator to act as a throttle body instead of using the one I posted. I could probably get a used/gutted carb that doesn't work for less than the $500 for the manifold. I'm trying to see if the cheap college student way will work right.
I feel stupid now for not knowing that it is called a "single plane intake manifold". I lookede for a while but didn't find anything, and there was a sticky right on top.
Hopefully the last question, am I able to take out the MAF without too much trouble, or is there way to integrate it with this setup.
Old Sep 30, 2008 | 03:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ok, thanks.
A lot of guys have converted carb manifolds. I did one myself a few years ago and it was VERY fast. The problem is the material. I do not have the ability to weld aluminum. If you can weld aluminum (injector bungs, rail mounts) than an intake can be converted for under $200 including fuel rails. I found that Supercharged Grand Prix regulators work great for home made intakes.
As for throttle body - you have a few different options, but I would not try using a carb. You need a reliable TPIS and IAC. I purchased a 'elbow' or 'doghouse' as some may call it to mount an LS1 throttle body to a standard 4150 carb manifold. This cost me some money ($265). The throttle bodies (76mm / 3") can be had for around $50. You can purchase a cast adapter from edelbrock for about $160. I needed a custom elbow/adapter/doghouse for my application. I personally like the monoblade LS1 throttle body, and I think the throttle response is much superior to a twin bore design.
You can also get an aluminum doghouse/elbow to run a TPI throttle body. A lot of the LT1 guys run them.
The real question here is do you NEED this type of intake. I'm running a 500hp supercharged 358 cubic inch small block.. If you have a near stock engine, with near stock cam and heads it probably won't run well with a short runner singleplane intake. A lot of these guys with singleplanes are in the low 11s to mid 10s. This is not for 13 second cars..
-- Joe
Old Sep 30, 2008 | 03:31 PM
miner's Avatar
Car: 88 Iroc-Z
I don't need this kind of intake. I am mostly thinking for the future. I'm thinking about doing a seroius engine rebuild/swap, and transmission swap in the summer, and I'm trying to get everything planned out ahead of time. I'm starting on figuring out what I should do to get the "most" for my money, when I do it. Thank you very much for your help.
