Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
problem not resolved!
Old Oct 3, 2008 | 12:34 AM
runningagain's Avatar
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
My truck STILL runns like crap! NO ONE IS ANSWERING ME?????? At least "BUMP" me. I respect this site but just tell me something! Rough idle, ANYONE?? How about the wrong intake gaskets? 1205 for the HSR? I have searched all I can, I just want someone to tell me something.
Old Oct 3, 2008 | 01:26 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: problem not resolved!
Are you running hsr on a truck?What kind?Rough I dle is your only problem?That could be alot of things.
Old Oct 3, 2008 | 10:09 AM
Ronny's Avatar
Did you run a datalog at idle? See what sensors are seeing.
Old Oct 3, 2008 | 11:56 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Might also help to have more information on your combo, from the engine itself to what electronic hardware and bin you are running.
Old Oct 3, 2008 | 12:14 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Could try adding a bit of timing at idle or bring the idle up to 800 until you get it going better.
Look at the closed throttle table and be sure its matched close to the main table settings.
Also when cold, the closed throttle table is not used.
The 100 Kpa cell from the main table is used for what ever RPM you are at until it warms up.
Get the TB blades opened up a bit to drop the IAC counts down to around 10-20, then do the reset on the TPS and IAC. Must do both after adjusting the TB mechanically.
Then see how it goes.
If the BLMs are still at 96 (pulling as much fuel as it can) then up your injector constant until they come up a bit.
Then work it backwards (as above) to get everything smoothed out.
Old Oct 3, 2008 | 07:50 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
Thanks, I will see what happens, when I talked to Kevin at AFI, I told him all the info on the datalog, everything sounds close except the BLM. I have set the idle many times, I also read a forum on stealthran.com that talked about the intake gasket for the HSR, I may have put the wrong gasket on in the first place, I don't remember the number, could someone verify if in is fepro 1205, or 1206? I planed on checking it out. I have used differant bins to try to see if any help, but the ones I tryed don't seem close, that's why I think I have a vacuum leak in the intake, make any sence?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
