Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
suggestions for fuel injection setup
Old Nov 3, 2008 | 06:40 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Hope this is the right section. Im thinking about switching to fuel injection over the winter. I have performer rpm/holley dp set up now. Can someone that has done the swap make suggestions to whats the best setup. Rest of my combo is in my signature. Ive been looking at accel dfi and holley. Thanks in advance for the help.
Old Nov 4, 2008 | 10:09 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: suggestions for fuel injection setup
There are lots of options. I personally like the setup that anesthes is using currently. see;"I miss singleplane intakes" in this forum. I am copying his setup for my T/A and putting a single rear-mount turbo to it. From what I can see, his setup will allow lots of future upgrades. You will need at least a stock tpi wiring harness, In-tank fuel pump/sender and ecm + sensors to do the swap. Everyone has their own opinion, but I think it will work best for me.
Good luck!
Old Nov 4, 2008 | 12:14 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
so is it better to piece a system together or buy one of the kits like accel or holley?
Old Nov 4, 2008 | 03:08 PM
I think it is easier to just buy a complete system, but not better. With a system in a box you will have directions.
Old Nov 4, 2008 | 03:15 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
thats what I was thinking, but i want to make sure. All components would match too. Thanks
Old Nov 4, 2008 | 10:38 PM
I like to be different... I dont like to pull up at the car show and have people say; "Hey, I just saw a setup just like that in super chevy..." Be careful and do lots of research, most systems are not emissions legal out-of-the-box. Also, there is always someone who will say "ah, I had one of those and ripped it out, because I couldnt get it to run right. Now I have a ^%#@$ and it is much better..." Etc...
Good luck!
Old Nov 5, 2008 | 02:11 AM
BadSS's Avatar
What are you looking for from the swap? A RPM intake and 750 DP Holley is a pretty well rounded combination when everything is dialed in. The Holley StealthRam performs a lot like that combo in the midrange RPMS,,, but will add a little more top end. SuperRam or FIRST would add more midrange and if ported properly might not cost you any top-end over what you have now. You'll see little benefit if any under wide-open throttle switching to a single plane EFI than you would if you just swapped to a single plane intake and ran the carb. A lot of the fuel mileage and driveability improvements when converting to EFI comes as much if not more from the ignition curves your able to give the engine (assuming you can tune a carb to begin with).
Old Nov 5, 2008 | 06:37 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Mostly looking for improved driveablilty. It is going to be mostly a street car now, with a few trips to the strip from time to time. I just want something that is fast, but I feel like I can drive anywhere. Anyone with a similar combo as me that has switched?
Old Nov 10, 2008 | 06:27 PM
AKS_Racing's Avatar
For most people a MRII (MiniRam) will do the trick. The short runners would really allow the 406 to breathe. If you are set on a SP (single Plane), there are many fine examples available that will make nice power from 2500-6500RPM (the significant TQ decrease is just a myth).
Compared to a Performer with a DP carb, either of these intakes will be a serious improvement from a driveability perspective.
Aaron
Old Nov 10, 2008 | 07:10 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
thanks Aaron....what setup do you have?
Old Nov 12, 2008 | 03:47 PM
AKS_Racing's Avatar
I have run all but the HSR on my personal cars. I ran the MRII when I moved to the 4" stroke, trying to kill some bottem-end TQ (unsuccesful). I currently run the SP set-up, and view this as the best manifold for my combination at the current time.
Aaron
Old Nov 14, 2008 | 11:08 AM
Ronny's Avatar
Most cost effective ECU is most likely the Megasquirt. I believe it does it all. Check their site.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
