Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Vacuum leak with HSR
Old Nov 8, 2008 | 10:17 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I need some help here. I've been working a a friends completely stock 89 IROC with a L98 and 74,XXX miles. He just recently bought the car and wanted a tune-up as the car was running poorly.
Replaced
Plugs
Wires
Cap
Rotor
Distributor
Fuel filter
After doing these things I found the car still running poorly. Long story short it had a large vacuum leak from the intake gaskets at the intake/ head surface. He decided now would be the time to start upgrading and purchased a used HSR. I finished installing the HSR tonight and found I still have the same vacuum leak. I used fel-pro 1204 gaskets and didn't notice any fitment problems on install. The leak is bad enough that after about 15 minutes of run time you could see a slight gray edge around the gaskets I assume from combustion gases escaping. I have no history on this car and can't get any as it was bought from a used car dealer in New York. I'm thinking about trying some Fel-pro 1266's (double thick) to see if that will fix it. Once I get the intake back off I will be checking the heads and intake with a straight edge. I wanted to know if anyone else had any ideas. Thanks.
Old Nov 14, 2008 | 10:20 AM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Re: Vacuum leak with HSR
The early HSR base's had fittment (warped) issues. I had a nasty oil leak, blow-by and had to remove it and have it milled flat where it contacts the heads. Then use thicker gaskets.
Mike
Old Nov 14, 2008 | 12:12 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Sorry I didn't update, but I figured it out the next day. This was an early one and I figured I would have to do exactly what you did. As it turns out when I was laying across the engine installing plug wires that were handed out to me by a buddy, somebody was wrong. When I saw #6 going to the drivers side I knew something was up. Stupid mistake that should have been checked first. Runs like a top now!
Old Nov 17, 2008 | 10:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Mike
This did occur with first molds and was talked about on these boards as if it were a wide spread problem. I believed I had the problem but it turned out to be somethig else. Upon talking with the proper people at Holley I was told that there had only been a handfull of intakes that were sent in that verifiably had the wrong angle.
86IROC112
Nov 27, 2015 09:54 AM
86maro_252
Oct 10, 2015 06:52 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
