86 2.8 v6 .. stalls when gas is pressed
Old Sep 19, 2015 | 07:09 PM
86maro_252's Avatar
I have an 86 2.8 v6 ...it dosent do it all the time but when it does its very irritating. .. it starts fine but once I press the gas is drowns out and sometimes completely dies ..it was a high idle at times and I've noticed that most of the time when it acts up the idle gets very high ( no tach so I don't know the rpms) ...ive changed fuel filter , wires , cap and button ...also fixed a few vacuum leaks ...any suggestions ?
Old Sep 19, 2015 | 08:29 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Re: 86 2.8 v6 .. stalls when gas is pressed
no sir, i have the same problem, only on cold starts though, once it warms up its okay so just try wasiting a few minutes before touvhing the gas and when you finally do press the gas, hold it for 15 seconds, thats usually what does it for me
Old Sep 19, 2015 | 08:35 PM
86maro_252's Avatar
Mine seems to do it also only on cold starts ..I'm gonna give that a try
Old Sep 20, 2015 | 08:40 AM
ex-x-fire's Avatar
You might have weak fuel pressure, dirty injectors, dirty maf, or a coolant temp sensor out of range.
Old Sep 20, 2015 | 08:42 AM
ex-x-fire's Avatar
Your Camaro has a carb & the other is fuel injected.
Old Sep 20, 2015 | 07:29 PM
Engine: LC1 V6 2.8L
Did not notice that he had a fuel injected car, my bad, even if it is fuel injected thoug, cold starts could still cause it to bog out
Old Oct 10, 2015 | 06:52 PM
86maro_252's Avatar
Thanks for the suggestions ... I was leaning toward the temp sensor ...it started getting worse, it was like I would loose fuel pressure while driving and I would have to pull over cut car off and when cut back on it would drive ... the craziest thing though I cut the muffler off 2 days ago and I haven't had a problem since ,it actually drives a little better now
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
89bird2.8
Sep 18, 2015 07:46 PM
rjcme
Sep 5, 2015 01:23 PM
SlowCamaro88SC
Jul 10, 2001 09:36 AM
